Old 08-17-2007, 08:50 AM
stirling is on a distinguished road
Gecko 201 current set question
Firstly Hi to all as this is my first post on the zone. Done a search and can't find this issue covered anywhere so...
motors are RHT23-260 as http://www.homeshopcnc.com/page5.html with a rated current of 2.8A per phase.
So according to gecko's instructions I should limit the current sourced from the drive to 2.8A by a current limit resistor with R=(47000*2.8)/(7-2.8) i.e. 31.333 or in practice a 33K resistor.
But elsewhere in the gecko docs is the statement: "The drive will always draw 1/3 of a motor's rated current when it is full wire connected" which of course this particular type of (4-wire) motor is.
So does this mean that although the motor is rated at 2.8A it will only ever be allowed (by the drive) to draw 2.8/3 i.e. 0.93A? in which case:
surely the motor will never achieve its potential power and secondly what was the point of limiting the current with the resistor?
I'm sure my reasoning must be wrong but I can't figure out why.
Old 08-17-2007, 10:30 AM
ger21's Avatar
The 1/3 of the rated current is for determining power supply requirements. Set the Geckos to deliver 2.8A as you have figured it. The motors will get 2.8a, but your power supply only needs to provide about 1/3 of that. Although a little extra won't hurt.
Old 08-17-2007, 10:58 AM
tauntdesigns's Avatar
tauntdesigns is on a distinguished road
Howdy,
My pdf says:
*"The maximum power supply current required is 67% of the
motor’s rated phase current."*
or 2/3rds
For the 2.8amp motors (31k ohms), do you round up to 33k ohms or down to 30k ohms resistor, or does it matter?
Thanks,
Jack
Walking is highly over-rated
Old 08-17-2007, 11:17 AM
Hi ger21 - Now I'm really confused... if the motors will get their 2.8A but only a 1/3 of it is coming from the power supply, where's the other 2/3 coming from?
Hi tauntdesigns - agreed. the pdf states 67% but in the stepper motor basics pdf it expands on this and differentiates between parallel and series connection. (in that paper it uses 1/3 and 2/3). I'm taking that to mean the 67% is for parallel connection which of course is not applicable to 4 wire motors.
33k v 30k, I thought - what the heck - let's give it a little more juice rather than a little less. Also the other .pdf modifies the 47000 multiplier to 47500 so I'm guessing it's not too critical
Old 08-17-2007, 12:38 PM
ger21's Avatar
I don't really know how to explain it properly, but it's a function of the way the drive works.
Drive Current Setting Question electron Stepper Motors and Drives 1 03-21-2006 07:52 PM
How to measure the current on Gecko drive. cnc2k Gecko Drives 12 11-16-2005 12:16 AM
gecko 210: low current draw? anthony Gecko Drives 2 05-28-2005 02:19 AM
Gecko power supply 2/3" current rating? JFettig Gecko Drives 4 01-06-2005 08:04 AM
Current question Christian Gecko Drives 0 09-26-2004 02:52 PM
