Old 04-26-2004, 05:39 PM
SJ781 is on a distinguished road
power supply questions
I am going to run 3 320 servo drives with servos that have a max current of 30a so I want to be able to use the full 20a that the 320's provide I also want to run the most voltage I can the servos were rated for 90vdc. the 320's are rated for 80vdc. Will it be safe to run a ps that produces 79-81 vdc no load current. I know the voltage will drop when there is a load but will the voltage be to high when the servos are'nt running? My next question is should I run a sepperate ps for each drive or one ps. If I run one ps would I be ok with one that produces 30-40a. I doubt that the servos will ever all be at max rated current (20a) at once. Most likely only one will ever be at max at one time.
Old 04-26-2004, 06:45 PM
balsaman's Avatar
balsaman is on a distinguished road
You should run no more than 80 volts. 75 would be better. I would go with one powersupply, maybe around 30 amps.
Those are big motors. What are you driving?
Eric
I wish it wouldn't crash.
Old 04-26-2004, 09:37 PM
I'm driving a mill/drill the plans are to get 250ipm rapids out of it. I've got 4 - 79Vdc 7A power supplies but I don't think they will be enough to drive them. The servos are 2100rpms@72vdc and 690oz/in at 15A.
How does a power supply work. ynneb DIY-CNC Router Table Machines 1 07-27-2011 10:40 AM
Diy Power Supply Choices berin DIY-CNC Router Table Machines 11 07-13-2005 04:47 PM
5 Volt Power Supply Tripping murphy625 General Electronics Discussion 13 02-27-2005 10:05 PM
Power supply calculations questions cnczoner General Electronics Discussion 0 05-31-2004 01:30 AM
4-axis and Contorler questions and power supply wakeboard DIY-CNC Router Table Machines 15 01-13-2004 06:40 PM
