| LinkBack | Thread Tools | Search this Thread | Display Modes |
Well I am starting the build of my control box. I have been simulating this circuit and it looks good. Here's the pic
Comments always welcome, Guillermo Last edited by Guillote; 07-26-2007 at 02:17 AM. |
| Hello Guillermo, I am wondering with charge-pump. What is the function of it? I ever found in DB-25 pin of parallel port,for Mach3. I am not good at electronic system. Please advise if you know. Cheers, Mongkol |
| The computer sends a lot of rubbish etc to the lpt ports and that could do anything from moving some axis to wreck havoc. With a charge-pump you need to feed it a stable 12KHz for it to activate motors etc. The computer will not send out a similar signal by itself but need a program to do it. Extra safety if you will so that you don't have to manually turn on and off things to prevent damage. |
| Hi, Mongkol Any machine tool is potentially dangerous. The charge-pump is a safety device. Mach3 will output on the parallel port a constant pulse train whose frequency is 12.5Khz whenever it is running correcty. You can use this signal to enable your axis and spindle drive. This function is often implemented in commercial breakout boards. Soon I will update the circuit to include spindle control. Guillermo |
| Hello Friends, The idea of using the internal supply of the PC to power de relays is tempting me . The problem I found is that when I measured the voltage difference of the parallel port's GND to the power supply's GND it was 0.25Volts . I can't connect them together since this might produce smoke or burn a track so I am thinking to use power supply's GND and leave parallel port's GND unconnected or at most connect the LPT_GND with Power_GND through a resistance. I would like knowing what do you think on the matter?Comments always welcome, Salu2, Guillermo |
| Google for missing pulse detectors, or watchdog timer circuits, there are many IC's that can be used starting with the simple 555. Al.
| My Charge-Pump circuit | Guillote | Gecko Drives | 1 | 07-23-2007 10:58 AM |
| Diy Charge Pump Circuit? | zigmart | General Electronics Discussion | 6 | 03-18-2007 07:28 PM |
| Charge Pump circuit | raytor | Machines running Mach Software | 1 | 10-16-2006 04:23 PM |
