Old 04-22-2004, 08:44 PM
Don C is on a distinguished road
holding power
Do you produce more power in half winding or full winding. I don't seem to get the hold I should using full winding. I have a 6 wire motor that I'm not using the center tap and reducing amp by half and voltage doubles. I am using 29v on a rated 1.8 v motor.
Old 06-14-2004, 12:01 PM
Dan Mauch is on a distinguished road
The reason may be that the Gecko stepper drivers automatically go to a reduced current mode after a few seconds. If this is unacceptable there is a jumper inside the case that can disable this function.
See the data sheet for this feature.
Dan Mauch
Camtronics Inc
dmauch@seanet.com
www.seanet.com/~dmauch
Old 06-16-2004, 06:56 PM
No I have disabled the reduction. It runs smooth but just doesn't have the power that my other router has which is running in unipolor. and on your responce to fried drive it was a typo. I used a 120k resistor in half winding. but I am using 24k in full winding. motors are 1.7v 4.7amp
How does a power supply work. ynneb DIY-CNC Router Table Machines 1 07-27-2011 10:40 AM
Diy Power Supply Choices berin DIY-CNC Router Table Machines 11 07-13-2005 04:47 PM
Need more power mvaughn General Electronics Discussion 49 06-15-2005 07:11 AM
E-Stop Hard Wire and to Software? Sanghera General Electronics Discussion 20 10-30-2004 12:22 AM
Typical power supply ynneb DIY-CNC Router Table Machines 0 04-27-2004 10:06 AM
