Old 04-16-2004, 11:16 PM
tpworks's Avatar
tpworks is on a distinguished road
servo motor voltage?
I recently purchased the G340 drives and in the notes about the motor voltage , I purchased some servo motors on Ebay some time ago and there are no spec on the motors. I contacted the manufacturer and they said they were made for a client and didn't have the specs but think they were 300 watt motors. and that they were made around 1980. the motors are new and never used. How do I go about finding out the voltage for these motors as they look to be a high quality motor and I really would like to utilize them.
Old 04-17-2004, 03:26 AM
*Registered*
ESjaavik is on a distinguished road
Looks like it also have an encoder or resolver built in. Look for rated speed on the label, if nothing on the label, I would guess 3000RPM. Run it up to this speed using another motor and measure the voltage generated by the motor. But really I think max current is more interesting than max voltage. If you know max current, the drive will use the voltage necessary to bring it up to this current. And if this is a small router/mill your motors seems big enough that it would very seldom be driven hard anyway. Your drive will only send enough voltage and current to your motor to keep the following error low. Assuming your PID is correctly tuned that is.
Another way to go is to hook the motor up with a load and test with max continous load and judge the max current setting by how much it takes to heat the motor so it is not comfortably touchable after 30min of this "abuse".
Other than that I would first of all try to contact Gecko support. From what I've seen (I'm not a customer) they are concerned about their customers also *after* the sale is made.
Old 04-17-2004, 03:34 AM
tpworks's Avatar
Yes, they have an encoder and tach. Thanks for the info.
Today I chucked the motor in my mini-lathe and checked the voltage at the top speed which says it's 2500 on the panel and it was 58v.
so if 3000 is the rated speed then the 77v power supply should work alright is this correct?
...He who makes no mistakes makes nothing! ...
Tom
Small servo systems and power supply imserv Product Announcements & Manufacturer News 4 04-03-2008 12:11 PM
Using surplus servo motors as spindle drive Swede Servo Motors and Drives 11 03-16-2008 09:05 AM
Servo Motor Running away. murphy625 CamSoft Products 38 02-27-2005 02:08 PM
Mixing servo and stepper ty1295 Servo Motors and Drives 0 01-19-2005 10:26 AM
steppers or servo drives mmjpotter Gecko Drives 14 03-30-2004 03:56 PM
