Old 06-11-2007, 02:29 AM
Nivea is on a distinguished road
Where is the wiring diagram (pin description)for the G100 ??
Im trying to wire it up but not sure what some of the pins are. I have checked on the support page at geckdrive. I recieved no documentation with it or the 203V's I purchased.
Thanks.
Old 06-11-2007, 07:29 AM
Argofanatic is on a distinguished road
G100 Documentation
Old 06-11-2007, 08:42 AM
That aint it...
Thanks Argo,
but thats all to to with software/firmware. I need info on pin descriptions first. Most are self explanitory however some are not, ie- each axis has +5v and a GND. Are they inputs or outputs and must they be connected? Also not sure of CH-I , USB. Also would be nice to know the max-min voltages for the analog and digital IOs.
Why is this not in the support page on their website I wonder. The documentation for the drivers was very helpful though.....
Old 06-11-2007, 10:19 AM
I agree the documentation is a little scarce and somewhat difficult to descipher.
If you look at the document called "G-Rex Programming Manual.pfd" included in the above linked zip file you will find detailed descriptions of the pins.
For your purposes all you need to hook-up are the Direction and Step pins to your 203V's. The +5 and GND (directly connected to the G100 power supply) pins are only there for convenience, not required.
need Eurospark 740 wiring diagram kh_khayat CNC Plasma and Waterjet Machines 1 08-02-2009 08:47 AM
need Eurospark 740 wiring diagram kh_khayat General Electronics Discussion 0 10-13-2006 06:54 PM
Control Box Wiring Diagram bigvinney General Electronics Discussion 0 01-22-2006 04:57 PM
Wiring diagram geckos freak_brain Stepper Motors and Drives 0 01-09-2005 12:25 PM
