Old 06-06-2007, 12:27 AM
Smackre is on a distinguished road
Gecko's actin weird
I have a 3 axis gecko's stepper controller. I believe its G201's.
Here is what its doing. Its either loseing steppers or gaining steps. I ran a program where it cut out a 1.5" circle slot and then feed down 0.01" and then did it over and over again. Ever pass ended up atiny bit to the left of the pass b4 it. But only 1 axis is doing it. and if you switch the X Y axis wires it changes to the other axis. So its not the stepper. It seems to be between the Computer and the Stepper Controller.
Any suggestions on what it could be. Could it be something simple like sertain wires in the printer cord are not good.
Old 06-06-2007, 07:56 AM
Gold Member
CJL5585 is on a distinguished road
If it moves in the proper directions when commanded to do so, then the Gecko's are doing their job.
The AMOUNT it moves, or the number of steps it takes is a function of the ballscrew, leadscrew, or threaded rod, and the values inserted in the software package you are using, and the integrity of the machine construction.
If you have leadscrews of different pitches, it could be a problem. If the values plugged into the software are not EXACTLY correct to about eight decimal places it could be causing a round off error in software. If identical steppers are not used, it could be a factor.
Check settings in software. Check for any backlash or endplay of screws during movement. Also verify that the axis move easily and are not too snug requiring additional torque on one axis. The drives only act on the information that is sent to them.
Hope this helps.
Weird problem with HHain post... TEX123 Post Processors for MC 4 11-25-2006 04:29 PM
Weird Things Happening At My Relay @.@ sunmix General Electronics Discussion 14 11-11-2006 09:59 PM
Weird stepper issue... WilliamD Stepper Motors and Drives 0 07-21-2006 11:11 AM
Very weird situation... saturnnights SheetCam 6 03-02-2006 02:08 AM
Weird? Klox General CAM Discussion 5 11-18-2003 10:04 PM
