Old 04-09-2004, 04:15 PM
Sanghera is on a distinguished road
G201 Adjustable Step?
I was just wondering if the Gecko G201 supports adjustable steps. It says that the driver can handle 10 microsteps, but I'm not sure if it can go full step, half step, and all that.
Also, what is the main difference between the G210 and the G201, is it that the G210 supports adjustable steps, and can go full and half step?
Thank you very much for your help.
Old 04-09-2004, 10:46 PM
ger21's Avatar
No. 1/10 only.
Yes. Full, half, 1/5 and 1/10.
Old 04-10-2004, 02:52 AM
So, do you think that it is worth it to put the extra moola for a G210 and have the adjustability?
Thanks.
Old 04-10-2004, 09:43 AM
ger21's Avatar
Usually, the only reason to get a G210 is because your computer or software can't output steps fast enough for the G201. Your motors will run best at the 1/10 step setting, anyway.
Old 04-10-2004, 03:55 PM
Is that for any motor? Why would they run best at 1/10 and not 1/8 or full step or half step?
Thank you very much.
Old 04-10-2004, 08:17 PM
ger21's Avatar
Generally, the more microsteps, the smoother the motor will run.
Old 04-10-2004, 09:23 PM
But don't you lose torque with microsteps?
Thanks.
Old 04-10-2004, 09:28 PM
ger21's Avatar
A little bit, but you more than make up for it in smoothness, and the elimination of resonance problems.
Old 04-11-2004, 12:21 AM
I saw some articles that say that microstepping drastically reduces torque, is this true. I have heard it doesn't make much difference in torque aswell. Is this right?
Thank you.
Ametek motors and step down ratio dowling177 Servo Motors and Drives 5 03-01-2005 01:24 PM
step angle question?? kywoodwrkr DIY-CNC Router Table Machines 7 02-22-2005 11:04 AM
Dirction / Step lines! bigal TurboCNC 2 02-06-2005 02:51 PM
Have problems with G201 and printer port Christian Gecko Drives 2 09-26-2004 03:44 PM
Choosing a step rate? Rhodan General Electronics Discussion 4 04-26-2004 10:42 AM
