Old 05-30-2007, 02:48 PM
embeddedJunkie is on a distinguished road
Tie G320 fault line to something ?
I'm using G320s to control a servo motor on a CNC project.
When I power up the system the fault light is on. The encoder voltage is 5V. If I turn the motor shaft the A and B channels go to 5V, 0.2V.
I think I read somewhere that the fault line needs to be tied to something, but I can't find what. Should it be tied to the 5V that feeds the encoder ?
Thanks.
Old 05-30-2007, 05:04 PM
Torchhead is on a distinguished road
That's one way. The 320's need a "reset" pulse of at least 3 to 5 secs that consists of the internal +5 (referenced to motor ground) being applied to the reset pin. Leaving the + ENC signal on that pin will perform the same function but makes the Fault signal unusable. In the event of a fault the drive will stop (read: lose postion) and then fire back up after it has gone through reset. If you want the drive to signal the control system it has faulted the simple jumper idea does not work.
On our interface cards we designed for servos to the G320 and G340 drives we put a 5 second reset pulse to the Error/Reset pin and then "OR'ED" the pins together on multiple drives to provide a multiaxis system shutdown on any fault. We also included a differential to single ended converter for the encoder signals.
At this point our interface cards only work with our Power Controllers but I just got protos in for a new card that will let them work with just about any breakout card.
tomCAUDLE
www.CandCNC.com
BOB's
Digital THCs
DXFTool Software
Complete Electronic Packages
Stepper & Servo Systems
Hand Controllers
Old 05-31-2007, 11:37 AM
Thanks, that solved the problem. I tied the fault line to Enc+, for now.
g320 question h_2_o Gecko Drives 4 11-21-2006 11:15 AM
Controller With G320 kkilst Gecko Drives 1 05-10-2006 08:07 AM
#9 spindle fault logos Fadal 16 01-18-2006 06:22 AM
Fault code Rufan Bridgeport and Hardinge Mills 5 09-27-2005 07:57 PM
G320 Fault light doesn't turn off lamote Gecko Drives 0 04-11-2005 04:39 AM
