Old 04-27-2007, 12:09 PM
Smitty911 is on a distinguished road
Clue less and looking for some answers.
Looking at the Gecko 203V as they seem to be made for people like me. Electricially challenged.
My understanding:
1.You take the wires from the motor and connect them in order to the 203V per axis.
2. Your plug somekind of power supply to the 203V.
a. How large if I plan on going someday to 4 axis and using 300-400oz stepppers?
B. Will one large unit take care of the power for all of them?
C. Are there some off the shelf ones that would work?
3. Than there is some magic happening
a. The 203V should plug into somekind of board to interface with the computer controller.
b. Who makes a good board that would work with the MACH 3 software?
Who give the best deals for the above?
Smitty
Old 04-27-2007, 10:50 PM
Richards is on a distinguished road
Motor connections: Four wires from the motor connects to the Phase A, Phase /A, Phase B and Phase /B connections on the G203. On the Oriental Motor steppers that I use, the Black wire goes to Phase A, the Yellow Wire goes to Phase /A, the Red Wire goes to Phase B and the White wire goes to Phase /B.
Power supplies: Log on to PartsExpress.com and look at the Avel brand toroid transformers. I use the 25V 500VA model that costs about $75. It produces 33 VDC if wired in parallel or 70VDC if wired in series. (Add the current requirements for all of the G203/steppers and pick a transformer that gives at least 75% of that current. I always pick a transformer that gives 100% of the current, but many others have said that picking a transformer that gives 66% of the current is satisfactory. In my opinion, spending $25 more for a larger transformer is cheap.)
Power supply accessories: Visit the PMDX.com website and look at the PMDX-8020 power supply (about $100). You simply connect the toroid transformer to the PMDX and the PMDX takes care of everything else.
Breakout board: While at the PMDX site, order one of the PMDX-122 boards. It works.
The parts that I've listed are a bargain, both in price and in the fact that they work. I have all of them and have used them heavily for well over a year without problems of any kind.
Old 04-28-2007, 02:14 AM
Richards,
Thanks for the lead I have ordered the parts listed from PMDX site and well when they get here I'll attack that problem.
Snip
Well the above is where things start getting really bad. You would think in 40+ years of being around I would pick up some electrical knowledge. Hasn't happen yet though.
1. I use the 25V 500VA model that costs about $75. It produces 33 VDC if wired in parallel or 70VDC if wired in series. How is this done? the difference between series and parallel? These wires from the transformer connect directly to the PMDX part?
Thanks again for the assist all the parts have been ordered and should be here within the week.
Smitty
Old 04-28-2007, 10:34 AM
Avel Y236801 Toroid transformer connection:
On the transformer's input side there are four wires, Black, Gray, Violet, and Brown.
If your incoming power is 120V, connect the transformer's Black and Violet wires through a fuse or circuit breaker to the power Hot/Line wire (usually Black). Connect the Gray and Brown wires to the power Neutral wire (usually White).
If your incoming power is single phase 240V in North America, connect the transformer's Black wire through a circuit breaker to one of the incoming power's Hot/Line wires (usually Black and Red), connect the transformer's Gray wire to the transformer's Violet wire, connect the transformer's Brown wire through a circuit breaker to the other incoming power Hot/Line wire. You'll have to use a 2-pole circuit breaker with 1-phase 240V power so that if either Hot/Line wire trips, the circuit breaker will disconnect both Hot/Line conductors.
On the transformer's output side there are four wires, Yellow, Orange, Red, Black.
If you want 25VAC out of the transformer (rectified to 35VDC (1.41 X 25V) at the PMDX power supply board), connect the Yellow wire and the Red wire to either J1 input on the PMDX power supply board. Connect the Orange and Black wires to the other J1 input on the PMDX power supply board.
If you want 50VAC out of the transformer (rectified to 70VDC (1.41 X 50V) at the PMDX power supply board), connect the Yellow wire to either J1 input on the PMDX power supply board. Connect the transformer's Orange and Red wires together with a wire nut. Connect the transformer's Black wire to the other J1 input on the PMDX power supply board.
(I make it easier to connect things by using DIN terminal blocks and 35mm DIN rail. The blocks cost about $0.50 each and the rail costs about $6.00 for a three-foot section.)
From the PMDX power supply, connect the POS output through a fuse to the Gecko G20x stepper driver. If you have four G20x drivers, you will need to have four wires and four fuses connected to the PMDX. Since the output connectors are only large enough to hold a 10 or 12 guage conductor, use DIN terminal blocks or some other method of branching the wires. DO NOT use a DAISY CHAIN or SERIAL configuration for the wires. Use a STAR or PARALLEL configuration.
On my system, I connect the PMDX's positive conductor to four DIN terminal blocks that have a jumper so that the four terminals act as one terminal with one input and seven outputs. From each of four outputs, I run a wire to a DIN fuse block. From the opposite side of each of the four fuse blocks, I run a wire to a G203's Positive Input. I connect the PMDX's negative conductor to four DIN terminal blocks that have a jumper so that the four terminals act as one terminal with one input and seven outputs. From each of four outputs, I run a wire to a G203's Negative Input.
Old 05-01-2007, 12:16 AM
Recieved some items today
I'm in Southern California so I believe we have standard 120v line. I will assume we will need to use a three plug grounded outlet.
What size Circuit Breaker? 10, 15, 20 amp like you would get at Lowe's or Home Depot? Or like this?http://www.minute-man.com/acatalog/P..._Breakers.html
I don't think this applies.
I'm not sure what I actually need here. I have three (3) 425oz steppers and three (3) G203V Geckos. To don't have the transformer yet so the wiring can wait for a moment.
This brings me also to an area on the Gecko that is printed "Current Set and Current Set". Does that mean that if the motors take X current than a resistor of the value needs to be connected across those two pins?
This sounds like an easy and clean way of doing this wire stuff. Thanks
I will be printing this page out and taking it to work with me so the EE can do the wiring stuff.
What are the chances of getting a picture of what you are talking about?
The motors came with eight (8) wires as follows:
Red
Red/White
Blue
Blue/White
Black
Black/White
Green
Green/White
There were no instructions so I assume the the same colors get connected to the same place. I could be wrong though. And that these pairs of wire will be connected though and extension cable directly into the gecko Phase A, -A, B, and -B.
Start EDIT:
I found on the Keling Inc. web site the specifications for the 425oz steppers. http://www.kelinginc.net/KL23H286-20-8B.pdf
It would appear that there are several ways in which to wire this. Looks like I need to read up on stepper motor operation to figure out which method. Good thing I read fast. Comprehension of the electrical will have to come.
Stop EDIT
There is also what looks like a trim pot on the top left hand corner, purpose?
I know that I am asking a lot of questions, thanks for your patience. The fire insurance premium is paid up, I just don't want to use the insurance for this. LOL
Thanks so much for you assistance.
Smitty
Old 05-01-2007, 01:22 AM
Answered a few of my own questions
These are Bi-Polar motors: http://www.kelinginc.net/KL23H286-20-8B.pdf
That leaves us with either series or parallel wiring of the motors. Which is better, I've read the information about stepper motors on Geckos site, but it really didn't cover (or I missed it) about one over the other.
Parallel will need a 36k resistor to keep the current less than 2.8 amps?
Wires will be connected to the Gecko:
PHASE A = A, -C
PHASE -A = -A, C
PHASE B = B, -D
PHASE -B = -B, D
PHASE A = BLUE/WHITE, RED/WHITE wired together
PHASE -A = BLUE, RED wired together
PHASE B = GREEN/WHITE, BLACK/WHITE wired together
PHASE -B = GREEN, BLACK wired together
Smitty
Old 05-01-2007, 10:54 AM
Fuses and circuit breakers are meant to keep the wiring from getting too hot. (The difference between your kitchen toaster and an extension cord is basically the guage and type of wire used. Believe me, you can make an extension cord heat up just like a toaster's elements by pulling too much current through the wiring.) So, based on that, I usually install conservative fuses in my circuits. On the input side of the toroid, I use a 7A Slo-Blow fuse. Between the power supply and the G203 modules, I use a 5A regular blow fuse. (Again, I'm protecting the wiring - not the devices. My intent is to prevent a fire not necessarily to pervent a device failure.)
From the KL23H286-20-8B data sheet, you can use a 70VDC power supply. The G203 can handle up to 20X the motor's rated voltage or 80VDC, whichever is lower. If you wire the motors as parallel, 20X 4.17V = 83.4V, so you would be limited by the G203 maximum voltage of 80V. (In actual practice, unless I need top speed, I've found that using 10X or 15X the motor's rated voltage usually works just fine.)
Adding the current of all motors together gives 8.4A. Multiplying that by 0.66 gives 5A and multiplying 5A by 70V = 350VA. So a 500VA toroid will work fine without getting too hot. (The 0.66 multiplier is generally used for CNC equipment as being reasonable.)
The current set resistor limits the amount of current that the drive will allow. It's important to use a resistor that limits the current to the motor to the motor's rated current or less. The forumula is: 47 X Amps / ( 7 - Amps), so, in your case 47 X 2.8 / (7 - 2.8) = 31.3K. You could use either a 30K or 33K 1/4-watt resistor.
You can get an idea of what terminal blocks are by visiting AutomationDirect.com. I use a local supplier, but the blocks at AutomationDirect look very similar to the ones that I use. Part no. DN-T10 is the terminal block. Part No. DN-EB35 is the end bracket, Part No. DN-EC1210 is the end plate. Part No. DN-4J10 is the 4-pole jumper. Part No. DN-R35S1 is the rail. Part No. DN-F6 is the fuse holder. Part No. WMS1B-6 is a 6A circuit breaker that can be used in place of the fuse holder.
(As far as uploading a photo of the wiring goes, I'll have to learn how that is done.)
The trim pot on the G203 is to smooth out the stepper. If you download the 'Stepper Motor Basics' White Paper from GeckoDrive.com, you see how that can help with some motors in some circumstances. With the Oriental Motor steppers that I use, I've not had to adjust the pot. I've tried, but the motor runs best at the factory setting. Your motors may run smoother after adjusting the pot.
I always use either parallel or half-coil wiring with my steppers. Serial wiring gives great low end torque (the same as the motor wired parallel) but much lower high end speed. If you read Mariss's white paper, you'll see the term "Corner Speed". That is the highest speed at which the motor can run before excessive heat starts to be generated. Mariss recently posted some formulas that help in 'guessing' the corner speed of a motor. Here are the forumulas:
1) W = (Vs * Th) / (10^3 * L * Ir)
Where:
W = motor power output in Watts mechanical
Vs = supply voltage
Th = rated holding torque in in-oz
L = winding inductance in Henries
Ir = rated phase current in Amperes
2) RPM = (0.191 * Vs) / (L * Is)
Where:
RPM = the motor's corner speed
Vs = supply voltage
Is = drive's set phase current in Amperes
So taking your motor wired parallel, you would get (0.191 * 70V) / (0.0068H * 2.8A) = 702 RPM as the motor's corner speed. If you wired the motor as series, you would get (0.191 * 70V) / (0.0272H * 1.4A) = 351 RPM as the corner speed. If you wired the motor as half-coil, you would get (0.191 * 70V) / (0.0068H * 2A) = 983 RPM as the corner speed, but only 70% of the torque of a parallel or series wired motor.
Wiring the motor as half-coil, you would use EITHER the A, /A OR the C, /C coil for Phase A and EITHER the B, /B OR D, /D coil for Phase B.
Remember that the Corner Speed and the motor's top speed are not the same. I have run stepper motors that have a corner speed of 1,500 RPM at 6,500 RPM. They get hot in a hurry when run at those high speeds, but it can be done. (I was testing the G100/G203 to see just how fast I could make a motor run.)
Old 05-01-2007, 06:11 PM
Thanks again
Well you haven't said to put it all in a box and send it back, so I'll plug along.
I will be reading and trying to understand your reply. I read the White Sheet on Geckos so the corner speed and a couple of other things make sense now.
I will be printing and reading the Gecko and Keling specification so that I understand (to a point) about what the correct method is.
Thanks for your replies.
Smitty
Old 05-01-2007, 11:17 PM
In the eighteen months that I've been pleasantly involved with testing and proving that Gecko products really work, I've had the chance to work with a lot of different stepper motors. Currently, I have more than sixteen motors on my test bench. They're almost all manufactured by Oriental Motor, but that's mainly because I've used Oriental Motor steppers in process control computer projects long before I learned about Gecko stepper/servo drivers. Frankly, I don't know that I'll ever buy another brand. That absolutely does not mean that there is anything wrong with any other brand of motor. It only means that I have confidence, based on years of experience, with one brand of motor.
I feel the same way about Gecko stepper/servo controllers. For the purpose for which they were designed, and within the sphere encompassing those design criteria, the Gecko products are also my first choice.
Mainly, I require that any process control product be absolutely reliable. I also insist that it handle anything within the design parameters of the process control computer for which the part was selected. It's always a big plus that the parts are affordable and that they come from companies that have a good reputation. Gecko products totally meet those requirements. There are limitations, such as a maximum of 80VDC, but those limitations are clearly stated in the pre-purchase literature.
Somewhere in the past, I heard someone say, "A poor carpenter always blames his tools." I've taken that to mean that it's up to me to know my equipment to the point that I know what each piece is capable of doing. Then, when I come across a limitation, I only have to select a different piece of equipment. It makes life easy.
One of the things that has made testing and evaluating equipment possible and even pleasurable is this forum. A lot of users freely give advice and relate their experiences with different brands of equipment. Most of the advice is trustworthy. Most of the experiences are based on a real desire to make something work. And, most important of all, there is a sense of family here where we sometimes play the role of the little brother who needs a guiding hand and sometimes we play the role of the big brother who has already had that experience. That free and friendly exchange of ideas and willingness to help whenever possible makes this community a great place to visit.
Old 05-03-2007, 12:31 AM
Agreed
The only reason I am attempting this is that people on this board are helpful. Spending over $1,000 bucks on an anchor would land me in the dog house very quickly.
Thanks for you support.
Smitty
  #11   Ban this user!
Old 05-04-2007, 03:35 PM
Connections
Well I have the eight wire 425oz steppers from Keling Inc. and the 203V's.
I have the leads from the Steppers twisted together to form four (4) pairs of wires. On the Gecko there are Phase A, -A, B and -B. Does it matter which pairs are connected to which phase?
The motor list:
A,-C Wired
C,-A Wired
B,-D Wired
-B,D Wired
How do the above relate to the Phase of the Gecko's?
Thnaks
Smitty
  #12   Ban this user!
Old 05-05-2007, 08:05 AM
Smitty,
Connect the Blue/White and Red/White wires to the G203 Phase A (Terminal 3).
Connect the Blue and Red wires to Phase /A (Terminal 4).
Connect the Green/White and Black/White wires to Phase B (Terminal 5).
Connect the Green and Black wires to Phase /B (Terminal 6).
If the stepper's shaft turns in the wrong direction, simply exchange the wires on Terminal 3 and Terminal 4.
An So it Begins...Building my first cnc router. No Clue, but what does that matter :) InventorJohn CNC Wood Router Project Log 44 01-17-2007 10:22 AM
looking for answers! redneck79 CNC Plasma and Waterjet Machines 9 08-15-2006 07:00 PM
New Guy, No Clue, Router Advice?? meyer712 DIY-CNC Router Table Machines 3 12-18-2005 08:07 PM
newbie looking for answers ecologito General Metal Working Machines 1 11-20-2005 10:04 PM
help with answers turmite General Electronics Discussion 2 01-21-2004 12:05 PM
