Old 03-30-2004, 04:25 PM
an0n is on a distinguished road
Unhappy encoder trouble
Hello, everyone I just bought a couple of geckodrive's only to find that the encoder's supplied with my servos's are too high cpr ones(1000cpr), and that the software cant supply enough pulses to give me a acceptable ipm. Are there any way to get the g340 to play nice with the encoder's except for getting new ones?.
I've thought about writing a program for a microcontroller to scale the pulses from the encoder whereas 4 pulses from the encoder(1000/4=250) set's off one pulse from the microcontroller to the geckodrive.
Does this seem like reasonable?
Old 03-31-2004, 07:07 AM
Bubba's Avatar
Bubba is on a distinguished road
Smile
As you have 340's, the answer is right in front of you
Read the documentation (and if you don't have it, you can download from www.geckodrive.com) and read up on the multiplyer function. It will effectively turn your 1000 line encoder into a 1000 line (multiplier 1), 500 line (multiplyer 2), 200 line (multiplyer 5), or 100 line encoder (multiplyer 10).
Also remember that as the line count goes down, so does your resolution so it is a tradeoff between speed and resolution!
For my purposes I set up a simple spreadsheet to show the various tradeoffs and then set my geckos accordingly. In my case, having 1000 line encoders, I used a 2 multiplyer and get satisfactory results.
Old 04-20-2004, 01:39 AM
Thanks for your reply, I shoud have read my manual more carefully first.
encoder issues rutexus Servo Drives 13 05-21-2006 07:49 PM
What's your max distance to encoder? murphy625 General Electronics Discussion 5 05-12-2005 11:57 AM
Need encoder recommendation Swede General Metal Working Machines 9 10-05-2004 09:01 PM
Encoder Trouble HELP!! ty1295 General Electronics Discussion 13 08-05-2004 06:47 PM
Encoder wiring balsaman Gecko Drives 15 12-30-2003 12:01 PM
