Old 03-28-2004, 02:43 PM
Don C is on a distinguished road
gecko 201 motor hookup
I have a gerber ar400 router that I'm replacing the old controller. The motors are all 1.7v 4.7 amp 6 wire. would I be better off with full or half winding for power and speed. and if I use full winding does that mean that my amps will be half. I'm going to use 3 gecko 201 drives.
Old 03-28-2004, 03:33 PM
Gold Member
Mariss Freimanis is on a distinguished road
If your supply voltage is 34V or less, run the motor half-winding and set the drive to 4.7 Amps.
If your supply is between 34V and 68V, run the motor full-winding and set the drive to 2.4 Amps.
Mariss
Old 03-28-2004, 03:49 PM
Don C
Old 03-28-2004, 04:29 PM
Urgundiz is on a distinguished road
Mariss, is this only applicable to geckos or there are some rule of thumb useful for any stepper?
Old 03-28-2004, 09:46 PM
Gold Member
The idea is the max supply voltage should be no more than 20 times the motor's rated voltage. That motor is 1.7V in half-winding and 3.4V in full-winding, which is where the 34V and 68V stuff comes from.
Motor power output increases proportionaly with supply voltage, iron losses (eddy current and hysterisis) increase with the square of the voltage. At 20 times, the motor case temperature will be near the max rated 85C. This is the ultimate limiting factor for the motor.
Mariss
Wiring an 8 lead stepper to a Gecko 201 ChrisJ Gecko Drives 15 05-02-2005 03:15 PM
Open Source Gecko 201 Look A Like? pminmo Open Source Controller Boards 5 11-06-2004 11:51 PM
Some Gecko 201 Questions mikie Gecko Drives 3 08-10-2004 12:40 AM
Gecko 201 for my steppers? snaggletto Gecko Drives 0 02-27-2004 11:22 PM
Gecko 201 jimini Gecko Drives 4 12-30-2003 11:45 AM
