Old 04-13-2007, 09:30 PM
Paraprop is on a distinguished road
G320 receiving feedback from linear scale
Instead of using the conventional encoder mounted onto the servo motor shaft, I am thinking of connecting a linear scale with a compatible signal onto the feedback inputs of the G320's.
This will allow to compensate for all the issues coming from reduction pulley system, ballscrew acuracy, backlash, etc.. Therefore it would just be one step short of telling to the CNC controller where we are exactly.
Given that this is not comon practice, am I missing something out which jeopardizes this approach or is it just a price issue ? Many do already have linear scales fit for DRO so the signal could be fed easily to the drives.
Old 04-13-2007, 10:00 PM
Gold Member
CJL5585 is on a distinguished road
Linear scales are used on many high quality CNC machines which require extreme accuracy.
The main reason they are not so common is price, oils and coolants and trash getting into the unit electronics. Most linear scales are made of etched glass.
Congratulations.
Old 04-13-2007, 10:04 PM
Al_The_Man's Avatar
This recent post explains some of the problems.
http://cnczone.com/forums/showthread.php?t=24817
Old 04-13-2007, 11:54 PM
Al thanks a lot for putting me onto this thread. Spot On !!
reading this I think it is the way to go.
rotary encoder on the servo or stepper
linear scale on the table
cheap rolled ballscrews
proper table guideways
proper ballscrew bearing
hardware able to collect the 2 feedbacks
Mach 3 plug in to sort it all out.
I am looking forard to this day to come
Daniel.
linear scale interface with servo machinemman Linear and Rotary Motion 2 03-17-2007 10:10 AM
Linear Scale interface ?? routerman Bridgeport and Hardinge Mills 2 02-03-2007 11:28 AM
IH Kit & Linear Scale SMW Precision Industrial Hobbies (Support forum) 2 04-17-2006 05:18 PM
linear glass scale error? beezerlm General Metal Working Machines 8 03-23-2006 10:40 AM
Homemade Linear Design, Feedback. MrBean Linear and Rotary Motion 22 05-20-2005 02:50 AM
