Old 03-26-2007, 08:59 AM
grubicm is on a distinguished road
Question Ethernet communication with GRex 100?
Hello Friends,
I have a brand new G100, and certain begginer problems
I don't want to use MACH3, but my own custom made software, and I want to communicate with GRex over ethernet.
Does anybody know something about g200x protocol and UDP messages exchange between PC and G100?
I got two firmware modules, one is GeckoMotion which is using USB, and another one wich is made for MACH. Which one supports g200x?
So far I tried to send discovery message to G100 over ethernet and there is no answer. GRex Loader is working fine, so it is not about cables
BTW, I asked questions to the Gecko Drive support team, there is no answer ...
Thanx in advance!
Old 03-27-2007, 07:04 AM
Just to tell you that I have succeded. Anybody interested in this way of "direct" control over GRex100 I'll be happy to share all I know.
Old 03-31-2007, 09:00 AM
Richards is on a distinguished road
I would like to know how to use ethernet with the GeckoMotion software. It seems that ethernet would allow any computer on a network control a G100 if ethernet were used instead of USB.
My application is a simple point-to-point CNC router sized machine (48" x 96") to quickly and accurately position a drill to place 5mm holes in cabinet parts. Tests have shown that by using the G100, G203, Oriental Motors PK299-02A stepper motors, 3:1 gearing and text files with GeckoMotion software, that speeds of 2,400 inches per minute are easily obtainable; however, USB with GeckoMotion is the weak link.
Any help would be appreciated.
-Mike Richards
Old 04-01-2007, 03:22 AM
Mike, I quit the Gecko Motion, because it seems like it is USB only, very slow and, a very weak feedback. Not good enough for me.
I don't have any motors or drivers yet, I got G100 so I can develop my own CAM software and interface to G100. My project is a plasma cutter which will have a PC as a console.
The file g200x.h is a C++ header that is the part of G100 and MACH documentation CD. It describes UDP messages that are exchanged via ethernet between PC host and G100. So far I wrote a software that send "discovery" message and G100 replies with full status information. I am focused in fully implementing g200x protocol and pack it in a DLL so I can go further.
When you assign an IP adress to G100 with GeckoLoader, once it is fixed there is no problem. I used crossed cable for the first time, latter I tried with a LAN switch with several other computers on the network and there was no problem so far.
You see, since I was a SW engineer I take a different aproach, software is the key
Max
Old 07-15-2007, 06:02 PM
FPV_GTp is on a distinguished road
hi
Join geckodriveATyahooDOTcom , Mariss Freimanis owner of gecko-drivers is more active there with more tech knowledgeable people also on his forum when it comes to G-Rex ( G100 , G101 ) questions ????
cheers
Old 09-02-2008, 04:39 PM
purvisl is on a distinguished road
Did anyone ever get the ethernet communcation working here? I am trying to communicate via Visual Basic.net over ethernet. I would appreciate any example code of anything that is even partially working. My application is not cnc.
Lan
grex bbrown2005 G-REX 1 03-18-2007 08:38 AM
So what CAN GREX do right now? PeteZ28 Gecko Drives 7 03-06-2007 08:17 AM
Grex and AB efrem G-REX 2 07-16-2006 10:29 AM
Grex 100 planeflier G-REX 3 05-12-2006 04:18 PM
Ethernet Communication with Fanuc 18i-T smabhyan General CAM Discussion 3 10-22-2003 10:45 AM
