Old 03-02-2007, 07:38 PM
electron is on a distinguished road
Max Supply Voltage to Geckos
My servos are rated at 45VDC Max Input, Can I supply the Geckos with 54 VDC and be safe? I was thinking the Geckos limited the Voltage and current but I don't want to fry something.
Ed
Old 03-02-2007, 07:56 PM
Bubba's Avatar
Bubba is on a distinguished road
Based on messages that I have had or seen from Mr. Gecko, you should not run the voltage of a servo more than about 5 volts above rated. so the recommended max would be 50 volts DC.
Others with more knowledge than I may respond.
Bubba
Art
Old 03-03-2007, 06:43 AM
Thanks for the Info
Which supply voltage and current for these PAP debutpic Stepper Motors and Drives 5 10-11-2006 03:23 PM
Bridgeport Power Supply - what voltage? damae Bridgeport and Hardinge Mills 3 02-03-2006 04:13 AM
Power supply voltage too high spoiledbrat General Electronics Discussion 8 06-13-2005 09:39 PM
How do I limit voltage out of a power supply? buscht General Electronics Discussion 11 01-05-2005 08:03 AM
Geckos, power supply and servos snaggletto Gecko Drives 2 05-22-2004 05:28 AM
