Old 02-19-2007, 05:12 PM
eloid is on a distinguished road
gecko drives
how many gecko drivers can be run off one pc with the printer port is the max 4axis? how you get round this if you need 5 axis ie maybe for a router lather with index chuck etc
If one needs more than 4 axis with printer port
264.0 Minimum HoldingTorque(oz-in) (HT23-400 motor)
does a break box help?
newbie thanks
Old 02-19-2007, 05:21 PM
ger21's Avatar
You add a second parallel port on a PCI card. I think you can run 7 Geckos independently. 6 axis + 1 step/dir spindle.
Old 02-19-2007, 08:42 PM
most laptops are limited for external pcima cards...for other junk....
is 6 axis on one paralle port or is the limit 4?
Gecko Drives Smackre Gecko Drives 8 09-11-2011 08:12 PM
Gecko 202 drives Pete Stenabaugh Gecko Drives 16 07-29-2006 07:39 PM
About the Gecko Drives... A2Nl301 Gecko Drives 5 02-08-2006 11:26 PM
Bridgeport servos with Gecko drives GalaticDan Servo Motors and Drives 0 03-17-2005 07:39 AM
Gecko Drives ninewgt Gecko Drives 8 06-23-2003 08:12 PM
