Old 02-14-2007, 03:14 PM
Soundstorm is on a distinguished road
First Gecko setup
I've been reading for quite a while now, and decided that Geckodrive is the way to go for me.
I'm buying a cnc flat bed mill wich is normally equiped with stepper motors and a weird custom controller. I'm goint to buy it without controller or motors and put my own (that I still have to buy) stuff on it. I really want servos and the Geckodrives.
But from what I understand, you can just hook up the Geckos to the parallel port and make it work with Mach3 (for example). But what if I need more than 4 axis? Isn't the parallel port limited to 4 axis?
I then thought of adding a G-rex, so I have 6 axis support and only 1 cable (usb preferred). I also have a bunch of I/O ports I could use. But then I can't use Mach3 anymore, as it only supports parallel port.
So what can I do? Is the G-rex really needed? I think a USB controller is better if I look into the future, Serial/printer ports start to disappear and I'd like to keep using my machine together with an up to date computer.
Old 02-14-2007, 06:43 PM
Gold Member
Mariss Freimanis is on a distinguished road
Mach3 has a G-Rex G100 software plug-in. Connection is via Ethernet.
Mariss
Old 02-14-2007, 07:21 PM
ger21's Avatar
You have several options with Mach3. You can use two parallel ports to control 6 axis, you can use a G100 as Mariss mentioned via Ethernet, or you can use an ncPod via USB http://ncpod.oemtech.com/ The Mach3 plugin for the ncPod is almost finished. A Mach3 plugin for PCI Galil cards is also being developed, but I'm not sure how many axis those will support, and they are somewhat expensive.
Old 02-14-2007, 08:04 PM
bstanton0101 is on a distinguished road
2 parallel ports
You can buy PCI card to add a second parallel port. Seems like the lowest cost route.
Old 02-14-2007, 11:17 PM
Gold Member
mlaws1172 is on a distinguished road
You won't be sorry buying the Geckos. They are the best value out there and the support is the best you can get at any price.
mike
Old 02-15-2007, 02:29 AM
Thanks guys.
If I would do it with 2 parallel ports, I'd need 2 PCI cards as I don't have any parallel ports on my desktop. But all my PCI slots are either used, or I can't use them because fans block them.
So a USB (or ethernet) connection would be great. And the IO ports on the grex are a plus as well.
I will have a look for the other ones mentioned to see if they suit me better. I didn't know there was a plugin for the grex, because I couldn't find it.
The only difference between the G100 and the G101 is that it's not in a nice case, right? If I'm going to put it (everything) in a nice case myself, I might as well take the G101 and save some money.
And if I'm using 2 servo's on 1 axis, I know I need 2 geckodrives, but can't I just split the wires coming from the G-rex, so 1 output goes to 2 drives? (with or without amplification). That way, I won't lose an axis.
Btw, does geckodrive only sell on their site? Or do they have a dealer somewhere in Europe as well? That would be a lot easier.
Old 02-15-2007, 04:21 AM
Greolt is on a distinguished road
Grex differences PDF
http://www.geckodrive.com/photos/G10...ifferences.pdf
DNC Setup phoodieman General CNC (Mill and Lathe) Control Software (NC) 6 12-18-2006 05:55 PM
Gecko 201 Connection Setup - Newbie. cjchands Gecko Drives 5 10-08-2006 06:07 AM
gecko CNC setup jarr88 Gecko Drives 0 06-17-2006 02:52 PM
To Gecko, or not to Gecko...that is the question! samualt Gecko Drives 11 09-22-2003 08:42 PM
Pins setup for gecko G 201 engraver Mach Software (ArtSoft software) 7 07-23-2003 01:17 AM
