Old 01-22-2007, 10:59 AM
BAM BAM is offline
BAM is on a distinguished road
Question connecting steppers
I have a controller using geckoG201 drives the current set resistor is set up for 3 amps I want to connect another machine to the same controller and be able to switch back and forth the steppers on this other machine are as follows 8 lead 200 oz in 3 volt 3 amps what connection do I need to make to the steppers bipolar series or parallel without changing the current set resistor in the controller.
Old 01-22-2007, 04:40 PM
AlanD is on a distinguished road
I think you need to restate your question more clearly (or in greater detail) and perhaps improve upon your subject-description - I can not understand your scenario.
Old 01-22-2007, 05:06 PM
snowshovelbmx is on a distinguished road
if I am correct in what you are asking than you want to be able to use one controller to power 2 different machines. by the sounds of it you already have the first machine set up for 3 amp/phase and you want the other to be 3 amp/phase as well, so you will need to find out which connection (series or parrallel) is 3 amps as conecting them differently will change the amperage and once you find out which connections will give you 3 amp/phase than connect your motors to the driver in that way.
connecting to 3d printer clint Computers and Networking 15 07-25-2011 03:49 PM
Connecting rod ACME I.C. Engines 18 08-11-2007 12:09 PM
connecting KrashKing405 Open Source Controller Boards 18 07-26-2006 05:30 PM
connecting to machines watzmann CNCzone Club House 2 06-20-2006 06:37 AM
Connecting Amp Enable keithorr CamSoft Products 5 03-21-2005 05:31 PM
