Old 01-09-2007, 09:51 PM
woodturn is on a distinguished road
Question 8 wire stepper motor help
So I posted this question in the stepper forum but I am still confused, can somebody help.
Here is my problem...I have a 8 wire stepper motor that I want to run in a Gecko 201 but I don't know how to hook up the leads from the motor to the drives. I know just enough to make myself dangerous. To make things worse I had no luck finding my motor specs on the web. My motor is a Astrosyn made by the Minebea Co. I think, model number 310-6. I also did a resistance test on the leads and found that there is no resistanc between the
orange and red
brown and yellow
green and blue
black and white
I would like to get the maximum amount of torque out of this steppers as well.
I thank you in advance to any insight you may have on either finding the specs on this motor or figuring out how to solve my problem.
dave
Old 05-12-2009, 07:46 AM
smaher is on a distinguished road
Astrosyn Minebea 23KM series 8 wire stepper motor wiring diagram
I have run into this exact problem. Unfortunately Minebea/Astrosyn are not very good about publishing data on their old motors. Using the "D-cell" technique outlined in another post, here are my results, given for both series and parallel wired motors using bipolar drive:
Parallel:
A+ ----- RED, WHITE
A- ----- BLACK, YELLOW
B+ ----- GREEN, BROWN
B- ----- ORANGE, BLUE
Series:
A+ ----- RED
A- ----- YELLOW
Connect BLACK and WHITE together
B+ ----- GREEN
B- ----- BLUE
Connect ORANGE and BROWN together
If you want to drive it unipolar, the individual winding configurations are as follows:
A Windings:
--------- RED (+)
--------- BLACK (-)
--------- WHITE (+)
--------- YELLOW (-)
B Windings:
--------- GREEN (+)
--------- ORANGE (-)
--------- BROWN (+)
--------- BLUE (-)
For unipolar drive, the BLACK, WHITE, ORANGE, and BROWN wires would be connected together (to the PS ground, for example), and RED, YELLOW, GREEN, BLUE would be driven for A+, A-, B+, B- phases, respectively.
I hope this helps someone,
Steve
Old 03-30-2011, 05:30 AM
danysan2525 is on a distinguished road
thaaaanks
i`ve been looking for this information for weeks. i realy apreciate it. thank you very much.
