| Hi guys, need advice on the connection setup on GECKO 201. I am a first time user here and would appreciate any help. I am trying it out with MACH 3 and there seem to be 12 outputs (from 25 parallel pins). Q1). Therefore 2 output per axis (X, Y, Z)-- Total of 6 goes into each Gecko Drive (dir & step)? Q2). What about +5 connection on GECKO, do you use outside power supply source? (could it be the same one as PC power supply)? Q3). What about "current" connection, what do you them for? Thanks for any advice..appreciate it. |
| http://www.cnczone.com/forums/showthread.php?t=14943 The first document is in dxf format, it can be opened in CAD. Post #4 is a pdf version of the same file converted via the courtesy of PMinMO. Ignore the type stepper notation. The drawing states it is for uni-polar steppers. That is incorrect, it is for Bi-Polar steppers. Something I overlooked before up-loading and cannot change. Everything else is correct. I personally have built six different electronic systems via this drawing, and many others have PM'ed me that they used it to wire their systems without problems. Good luck on your project. Jerry Last edited by CJL5585; 10-07-2006 at 09:44 AM. Reason: To add information. |
| Thank you Jerry, you are my man... A lot of good clarification on the link you sent to me. Yet, there are few questions I would like your expertise on: 1. Source of 5V supply that you said can be obtained from anywhere (wallmart, etc...) Question is can you connected to the computer powersupply, it has 5, 12+, 12- Vdc? 2. You stated that " On the breakout board CONNECT TERMINALS 18, 19, 20, 21, 22, 23, 24, AND 25 TOGATHER." So in other word, if not connected these pins together, they are isolated ground? From MACH 3 document, i thought coming out from the PC parellel port, these pins are "already" connected together? 3. Again, i am very newbie when comes to "BREAKOUT BOARD", my understanding is that only make the wiring connection easier? So does anyone just ignore the breakout board, and try to connect each wiring directly to the parellel socket pin? |
About Pins 18 thru 25: These pins are (or should be) internally connected to a common ground point inside the computer parallel port. These pins are normally also connected via the traces on many of the break-out boards. The reason for showing these pins connected is due to the fact that some break-out boards do not have the pins connected togather at a known common source and this can allow ground loop signals to occur. Many qualified electronics personnel cannot find ground loop problems, and someone without experience will almost never find the problems which are intermittant in nature. Break-out boards are an extension board for the parallel printer port in its most basic function with screw terminals. However, BO boards have been taken to a higher level due to the fact that some are available with opto-couplers, some with driver IC's, some with both, and some with LED's to indicate outputs and inputs, they are also available with other options. Some people make a custom cable by-passing the break-out board, and some blow up their computer in the process. The questions one should ask himself is "What are my electronics skills in tracing wiring and soldering", and "How brave do I feel"? Hope I have given some information that is useful. Jerry Last edited by CJL5585; 10-07-2006 at 08:41 PM. Reason: Correct one word. |
| Thanks again Jerry. Your clarification is appreciated it. Just one thing, could 5V blow the computer? And what kind of BO board are you suggested? The ones that I see is just plain external board, can't figure out how would it protected if something goes wrong. Appreciate it. |
| Inside a computer, almost all functions are based on 5 volts. So, as a result of this, any connection which may cause a problem with the 5 volt logic can have very serious consequences internal to the computer enclosure. Although computers on the one hand are dependable and can operate for years without any outside interference, they are very delicate machines where their operating voltages are concerned. Sometimes what seems to be a very minor mishap to the user can be a total disaster to the digital logic circuits; So, 5 volt mishaps can totally destroy a computer. Here is a link to one of the best breakout boards offered for sale. The price is less than $30.00. It is buffered (In other words, the internal computer port is isolated) from anything attached to the breakout board terminals. http://www.cnc4pc.com/Bidirectional_Breakout_Board.htm Jerry |
