Old 01-04-2004, 03:07 AM
jimini is on a distinguished road
Gecko 201's with TCNC
Hi Gang can anyone give me a good starting point to set up the motion parameters in TCNC?
My X axis is giving me headaches, I've replaced the X Gecko unit thinking I'd blown it, but it's OK.
I get rapids of 160 ipm on Y but X doesnt want to cooperate.
It is considerably heavier, I was getting good movement but losing step. I know going too fast.lol.Triple checked the wiring too.
What I would like to know are some good settings to start with.
Like max. speed (HZ) 40000
max acc. (HZ) 30000
max start spd (HZ) 10000
pulse width (uS) 2
these are the settings I tried on my machine.Just X axis misbehaves and its running quite free although fairly heavy.
computer= 200mhz IBM
steppers #34 4.5v 1.4a sanyo Denki
48v ps (55v no load)
1/2 x10 acme rod
Gantry style cutting area 29" x 15" all metal construction using skate wheel bearings.
I've tried settings to 60000 doesn't make any difference to Y and Z
Old 04-18-2004, 10:54 PM
tpworks's Avatar
tpworks is on a distinguished road
try switching the x and y motors to see if there might be a problem with the motor. I have those same motors and they just weren't strong enough. so I found some double stack of the same motor on Ebay and it solved my problem. the amp rating being 1.4a to 2.8a with a brewington driver.
...He who makes no mistakes makes nothing! ...
Tom
Old 10-24-2004, 09:37 AM
ivanfinlay is on a distinguished road
Hi Jimini,
Sorry I cannot help you, but I see that you are getting some very fast rapids.
I myself have been trying to set up Gecko 210s with very little joy. I am using size 34 double stack motors 2.5v 4.5amps, and they will not run at better than 100mm per min.(4"") at 24v supply. What current resistor are you using?.
My leadscrews are 2mm pitch and motors 200 steps per rev.
Old 10-24-2004, 02:24 PM
Thumbs up
Ivanfinlay
I have my problems resolved now.
I'm running @ 55v and the current set resistor is around 13k to give me 1 1/2 amps. It's been quite awhile since I set it up.
Working very well with Tcnc4.
I have 1/2 x 10 acme rod and homemade teflon rod nuts, I cut at about 35" min. I have small bits 1/8", 3/32" so any faster tends to snap them with deep cuts in wood.
I had to mess around with the acc, and start speeds.I also replaced my Z motor size#23, and I was only cutting at 1/2 depth. Turns out it's a 400 step motor, can't stop the shaft by hand, even on the spider coupling body....Jim
Gecko Drive, Banner Competition, Finalists Voting ynneb Polls 31 03-23-2005 11:04 AM
Gecko vs Rutex samualt Gecko Drives 20 10-21-2004 02:48 AM
Servos or Steppers..... and other gecko related questions UKRobotics Gecko Drives 11 04-19-2004 03:14 PM
To Gecko, or not to Gecko...that is the question! samualt Gecko Drives 11 09-22-2003 09:42 PM
GECKO 201's ? ninewgt Gecko Drives 3 06-13-2003 01:49 PM
