Old 12-28-2003, 06:51 PM
balsaman's Avatar
balsaman is on a distinguished road
Encoder wiring
I seem to have developed(?) a problem with my x axis. It faults randomly. I did some testing and it seems I am loosing some position as well. In 200 1" moves (back and forth) I lost 50 thousands of an inch.
I ran a new encoder cable directly from the encoder to the drive outside the cabletray/cat-tracks. Same problem. switched the x gecko drive with the A(rotary axis) drive. Same problem. I am starting to wonder if it's the encoder itself, but I want to eliminate some more stuff first.
Question: I use 8 conductor shielded cable for the encoder. 4 twisted pairs and a shield. I only use 4 of them. Should A and B from the encoder be a twisted pair? or should I use a wire from one pair for A and a wire from another pair for B with the other wires from the pairs grounded? Or just cut off? I use a twisted pair for the +5 and 0V. The shield is tied to ground at the drive end only.
Anyone else have an idea what's wrong?
Eric
I wish it wouldn't crash.
Old 12-28-2003, 07:30 PM
Gold Member
Mariss Freimanis is on a distinguished road
Eric,
Never have 2 signals on the same twisted pair! The cross-talk between them will be terrible.
Send encoder channel A on one wire of the pair, send either Ground or +5VDC on the other wire. Use a seperate twisted-pair for channel B (ground or +5V on one wire, channel B on the other).
Mariss
Old 12-28-2003, 07:31 PM
Al_The_Man's Avatar
Eric, I would not think it was the encoder at this stage, especially if the error is repeatable, the 50 thou error I suspect may be due to backlash?
If you use an encoder cable with independant pairs, it is customary to use a twisted pair for the A,/A & B,/B pair etc
The shield should only be grounded at one end, Usually the amp input end as this is usually closer to the main cabinet gnd.
Due to noise problems I had on one installation, I have been using belden 9891, I believe this is an ethernet cable, but it has one pair which is larger than the other conductors which I use for the power pair. I have had no problems since with any of the retrofits I have done.
Is your encoder on the motor or on the final motion actuator, i.e. ball screw or slide?
Al
Old 12-28-2003, 07:32 PM
HuFlungDung's Avatar
Moderator
Hi Eric,
I don't know right off if twisted pairs does much of anything for shielding low voltage wires. I know it cancels the field self induced by motor power wires, but that is the only place where I have heard that twisted pairs accomplish anything. But, you're the expert on that anyway.
You can maybe get ahold of cable with shielded pairs, too, all wrapped inside of a larger outer shield. But, I somehow doubt that encoder wires would crosstalk to each other anyway.
Can you swap encoders with another axis to find out if the problem follows?
Whatever is counting your encoder output is what I would suspect. Is that in your drive or in the computer?
Old 12-28-2003, 07:47 PM
balsaman's Avatar
Hu, the drive counts the encoder pulses. I have eliminated that as the problem. I am no expert...just know enough to be dangerous.
Al, there is backlash, but the error accumulates the longer the machine is run. Backlash errors are not cumulative.
Mariss, I used one wire from a pair for A, another from a pair for B. The +5 and 0V are on a twisted pair. The rest of the wires (one pair, and the two left over from A and B) are cut off on the encoder end, folded over and taped on the drive end. Will tieing them to ground at the drive end help? If I make the +5 and 0V the wires twisted with A and B I have to open the encoders and resolder. I can do that if it's the best way.
Thanks,
Eric
Old 12-28-2003, 08:34 PM
Gold Member
Having the unused wire of a pair grounded helps shield the signal carrying wire. Ground them at the drive end only to "encoder minus".
You mentioned on the "geckodrive" group the LEDs are dimly "on" while the motors are running. I looked at your ERR/RES circuit but could not make out the resistor size. If they are 10K or less, the LEDs will be partially on. That should be no problem though.
A bad STEP/DIR cable can cause problems like that as well. The drive may be faulting because it is seeing a burst of noise pulses it stupidly thinks are steps. Try gently wiggling the cable. See what the effect is.
Mariss
Old 12-28-2003, 09:11 PM
balsaman's Avatar
I will ground left over signal wires and try again.
The resistors are 4.7k.
Thanks for the help.
Eric
Old 12-28-2003, 10:09 PM
Gold Member
Let me know if that helps. By the way, are you using a new PC? Some of the newer PCs have 3.3V logic swings on the parallel port instead of the expected 5V. This can cause trouble.
Mariss
Old 12-28-2003, 10:30 PM
balsaman's Avatar
Tied all the left over wires to enc- and same thing....I will have to try a new parallel cable I guess. Wiggling the cable has no effect. The computer is a Pll 233.
Funny thing is, this is the only encoder cable that doesn't run along side the DC motor cables (and noisy router motor cable) all around the machine and thru the cat tacks etc. It goes nicely all alone to the back where the encoder is. The motor is on the oposite side of the leadscrew. Yes the couplings are tight.
Eric
Old 12-28-2003, 10:51 PM
Gold Member
Eric,
What revision number is your drive? Later versions have the REV number screened on the board area covered by the main connector. Our current version is REV-7.
Another possibility is a badly misaligned encoder, an encoder wheel that has a bend in it (metal wheels only) or has some crud or foreign matter on it. This is where the CH-A and CH-B signals aren't in quadrature for a portion of a revolution, or a channel drops out (crud on wheel or bent disk). This drives the quadrature decoder nuts and will result in errors or a FAULT condition.
This is best tested for with a scope. Barring that, cause the motor to move at 5 to 10 RPM. See if the motor acts or sounds funny at the same "clock" location on every revolution. If it does, it's your encoder.
Mariss
  #11   Ban this user!
Old 12-29-2003, 09:09 AM
balsaman's Avatar
I have tried two drives. The one in there now is one that was replaced in September? by you when you recalled a few drives. I will check the encoder by your 10 rpm test today. I have access to a scope too so I will try that if need be.
Thanks,
Eric
  #12   Ban this user!
Old 12-29-2003, 02:38 PM
HomeCNC's Avatar
HomeCNC is on a distinguished road
Eric,
How long is this cable. Is it the longest of your other ones?
Jeff Davis (HomeCNC)
http://www.homecnc.info
encoder issues rutexus Servo Drives 13 05-21-2006 07:49 PM
What's your max distance to encoder? murphy625 General Electronics Discussion 5 05-12-2005 11:57 AM
Encoder output into 2 different inputs? murphy625 Servo Motors and Drives 2 03-23-2005 10:36 AM
Need encoder recommendation Swede General Metal Working Machines 9 10-05-2004 09:01 PM
Encoder wiring hookup help ty1295 General Electronics Discussion 1 07-04-2004 10:00 AM
