I am trying to determine the current set resistor for the G212. I have a 48V 10A unregulated power supply and I am using these motors wired bipolar parallel. These are rated at 2.8A/phase when wired bipolar parallel. Does that mean that I use a 16 kohm resistor? http://www.kelinginc.net/KL23H286-20-08B.pdf Any help would be appreciated. |
| I see 47*2.8 / (7-2.8) = 33Kohms according to the formula in their docs. Right?
| 5% 1/4 watt resistors from Radio Shack work just fine (1/2 watt will work just as well), I have a similar Kelinginc stepper on my 201 gecko. I believe I picked them up from Radio Shack at 1 dollar for 5 resistors. Hope that helps!
__________________ (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) "If the women don't find you handsome, they should at least find you handy" -RedGreen show. |
| OK so lets see if I understand this right, the formula in my G210 literature I downloaded from the gecko website is R = 47 * I / (7-I) for the high range 1A to 7A So the specs for the Keling KL34H2120-42-8B say Unipolar 4.2 amps (amps is I ?) 4.7 volts Bipoar series (that means Bipolar I assume) 3.0 amps 6.7 volts Bipoar parallal 6.0 amps 3.5 volts Using the formula I got Unipolar 70.5 Kohms Bipolar Series 35.3 Kohms Bipolar parallal 282 Kohms looking at some other posts leads me to belive these results are right. Bipolar parallal with a 220Kohm 1/4 watt 5% radio shack resiter should give me 5.77 amps, a 315Kohm would give 6.09 amps, those are the closest two choices Radio Shack lists Bill |
| http://www.luberth.com/cstep/hardware.htm scroll down to the bottom of the page for the gecko resistor calculator makes things simpler |
| http://www.weethet.nl/english/hardwa...calculator.php There is a very handy little utility Also Radio Shack part # 271-312 Had resistors very close to what I needed for my steppers. http://www.radioshack.com/product/in...entPage=family Bill |
#10
| http://www.geckodrive.com/photos/G201_REV-5_MANUAL.pdf I just noticed tonight that the instruction manual has a picture of the drive, which has the resistor values listed right ON the drive, DUH :-). I should have a shiny new 201 to look at soon, should be in my mailbox this week :-). Bill |
#11
| http://www-k.ext.ti.com/srvs/cgi-bin/webcgi.exe?Company={5761bcd8-11f5-4e08-84e0-8167176a4ed9},kb=analog,case=obj(33635),new Parallel resistor calculator - calculates two standard resistors that will parallel to give an arbitrary resistance. Aaron |
#12
| Well if you calculate what the end result is from a standard resistor, the amperage is so close it isnt worth a lot of fiddling to fine tune it to .1 amp or less. In my opinion anyway 5.9x amps is gonna work just as good as 6.0. |
