Old 09-04-2006, 10:33 AM
Deviant is on a distinguished road
Q: Breakout board for 320s?
What's the breakout board that you suggest for use with the 320?
I know of two that I'm looking at. cnc4pc's and pmdx's.
However I'm not electronics incline enough to know which one is better.
Are there other breakout boards that I'm missing?
Thanks.
Old 09-04-2006, 12:34 PM
Gold Member
mlaws1172 is on a distinguished road
Take a look at CandCNC's boards. They have some very nice boards and their support is great.
mike
Old 09-04-2006, 12:54 PM
la_coterie is on a distinguished road
Have a look at http://www.campbelldesigns.com/ maybe cost more but opto isolated
Old 09-04-2006, 02:16 PM
Gold Member
CJL5585 is on a distinguished road
Thanks.
I recommend that you go with the CNC4PC. It has everything that you will need for the 320's. It is simple to hook up. You will need a 5 Volt DC wall-wart plug in power supply, as it uses external power. This however, is an asset and not a liability.
For the price, it is hard to beat.
Old 09-04-2006, 02:35 PM
yup.
I'll eat my words CNC4PC are opto isolated and I've just seen their new board as well. It looks like the one to go for - unless anyone knows better...
Old 09-06-2006, 08:17 AM
Which cnc4pc board? They have 3 it looks like.
Old 09-06-2006, 09:07 AM
Gold Member
The C10 Bi-directional board.
http://www.cnc4pc.com/Bidirectional_Breakout_Board.htm
Old 09-06-2006, 09:39 AM
Is there a reason to go with this board vs the others listed? Would the multifunction board at cnc4pc be better?
I'm really in the dark on the electronics aspect. I expect to post a good number of questions once I get to the point of mounting and wiring up the motors/encoders.
Thanks for the response.
Old 09-06-2006, 10:50 AM
the multi function board would be better if you want to control the motor speed via the program using a vfd (variable frequency drive) and need relays to control other things
All depends really..
Old 09-06-2006, 02:32 PM
Gold Member
This link is a comparison of all the CNC4PC breakout board features.
http://www.cnc4pc.com/BB.htm
I have a full schematic in pdf format on the Gecko forum for the wiring of drivers, encoders, and servos for the 320 and 340 units. Do a search for Gecko 320. I would give you a link to it, but cannot while doing this entry.
Jerry
Old 09-06-2006, 06:27 PM
Gold Member
Jerry
I could not find it, so I will upload it again here.
Use the schematic for wiring of the drives, encoders, servos. Ignore the other wiring as you will not be using the same power supply, breakout board, the fan connections, and some of the other options.
This should answer almost all the questions you may have.
Last edited by CJL5585; 09-06-2006 at 06:35 PM. Reason: To Add comment on wiring pdf.
  #12   Ban this user!
Old 09-06-2006, 06:29 PM
I found it earlier.
I clicked on your name and viewed posts by you.
But thanks for the repost.
According to your comparison link post. IT looks like the c10 isn't optoisolated. Which someone above pointed out is important?
