Old 12-16-2003, 02:10 AM
jimini is on a distinguished road
Gecko 201
Hi All
Can someone tell me if I should leave all my parallel port input pins floating or should I pull them high with 10k resistors?
I'm using a homemade breakout board and the Gecko 201's with steppers.
In my Camtronic controller the pins are pulled high, but I'm not sure about the Gecko's....Jim
Old 12-16-2003, 02:16 AM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
I'm not using a resistor, seams to work.
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 12-16-2003, 02:21 AM
Thanks Paul I didn't want to do any damage I gues you hook 5v to the dir/step common connector?
Old 12-30-2003, 02:01 AM
All right I've got my Gecko's installed with a 48v supply and WOW rapids of 160 ipm, compared to 15 ipm with another controller and 24v.
But what I'd like to know now is how can I tune the drives?
The instructions say to run the motors at 1/4 rpm I think, how might I get them to turn so slowly?
Old 12-30-2003, 11:45 AM
balsaman's Avatar
balsaman is on a distinguished road
You will need to set that speed up in the software. You could set the max speed way down or write a gcode with a very low feedrate.
Eric
I wish it wouldn't crash.
Wiring an 8 lead stepper to a Gecko 201 ChrisJ Gecko Drives 15 05-02-2005 03:15 PM
Open Source Gecko 201 Look A Like? pminmo Open Source Controller Boards 5 11-06-2004 11:51 PM
Some Gecko 201 Questions mikie Gecko Drives 3 08-10-2004 12:40 AM
gecko 201 motor hookup Don C Gecko Drives 4 03-28-2004 09:46 PM
Gecko 201 for my steppers? snaggletto Gecko Drives 0 02-27-2004 11:22 PM
