Old 07-31-2006, 09:34 PM
Pete Stenabaugh is on a distinguished road
G202 drives
Does anyone know off hand, if the auto-current reduction on the G202 is 'enabled' by default from the factory. I already have my gecko's installed and it is a pain to have to remove them to check this out.
Also, on another topic, I had posted earlier about wiring up for an E stop. From what I had read on this forum, it appears as though I can route my +5vdc through the E stop button, before it gets to the gecko's in the power supply cabinet. If this is true, then this is an easy thing for me to do. I would be using an NC e-stop button to open the circuit to the gecko's, so it should stop all the gecko's at the same time.
Thanks,
Pete
