my problem is that i can step in one direction only (Tabing in mack3 demo) try to tab in the other dir and nothing. Things that i have done: Swapped motors swapped drives swapped step/dir pins on lpt Now I thinks its either the drives or the software or the Mobo. Things i am going to do. swap mobo on pc swap power supply 5v and 28v reverse direction of stepper wiring at stepper. This all came about after hitting the home in mack3 mill. it went home and then would not come out to play. any ideas on diag or soultion pls. Paul |
Monitor the dir pin and write a gcode and use the mach program itself to see if it switches. Or you can watch tthe keds in the setup program it see lf to see if they go on and off and monitor the pin at the same time. Either a meter or even a cheap logic probe could monitor the pin. Or unhook the dir pin from the systemm and tie the dir pin highh and low and see if it switches direction. Seems much simpler than just changing things at random and maybe iintroducung more problems... Garry |
| Hi Garry. You are correct , unless its the driver board I am interested in the logic of diagnostics. The step counters are moving so Mach3 thinks that the pins are sending. I will acquire a logic probe and see if the pins are high or low. Mach3 prefers the pin low as it gives a better current tolerance. Paul |
| Garry just to keep you in the loop. I checked the Dir pins on the mobo and nothing. (set mach3 to hi and low) Replaced mobo and all is as should be, Thankx for your input, very helpfull. I will also replace the wirering loom to the drivers as this is also possible short site. I can't think of anything else that could have caused this one. Paul Paul |
| Just an update for anyone following this, It was not the MoBo, it was the 5v from the midi port. I was getting 3.2v instaed of 5v, Took 5v directly from the psu and all is now fixed. Just thought some one might like to know. Paul |
