Is it safe to use an 11 Amp psu to power 3 gecko 320's and 3 7.5 Amp (max) motors - IF i confine the movements to one axis at a time, and NO CUTTING! I ask this because I am having some serious problems with my bigger (24Amp) psu which needs to be repaired, but I would like to see my machine running - ie setup software and tune the drives. If you think it's risky, I can just disconnect two of the drives, and only have one motor connected at any one time. Thanks guys |
| If you have set the current limit screw to match your motors you will be fine. I run three G320's on 10 amps on my drill/mill. Under normal use of the mill you will not be using very many amps per axis.
__________________ Thanks Jeff Davis (HomeCNC) http://www.homecnc.info (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Mach 2 safe limits ? | qsacracer | Mach Software (ArtSoft software) | 6 | 02-21-2005 01:33 AM |
| Camsoft Handwheel problems | Ben Olson | CamSoft Products | 32 | 07-16-2004 10:17 PM |
| These linear rails. What is the retail value? | Bloy2004 | DIY-CNC Router Table Machines | 9 | 07-07-2004 09:59 PM |
| Siemens System 8 (G53, G40?) | RLMTS | Machine Problems, Solutions , Wireless DNC, serial port | 6 | 10-06-2003 02:56 PM |
