Ok i got my questions answered somewhat in the other forum, but I need some results. Trust me guys I have looked high and low for some of this stuff, but am getting no where. I have a 4 AB servos, stats: 5.5 A continuous 30 A peak Torque Stall 3.1 lb/in max speed 5000 rpm 7.4 v/k rpm 1000 ppr encoder, with 9 wires. 2 Questions: 1. The encoders are incremental optical encoders, and have 9 wires, like so: White: DC input 5 V DC Black: DC return Red: Channel A Violet: Channel A_ Green: Channel B Blue: Channel B_ Yellow: Channel Z Orange: Channel Z_ Shield: Floating How would I wire these to a Gecko 320 Servo Drive? Can I even wire it at all? 2. I want to make a light to medium duty accurate cnc machine, accurate enough to do pcb work, but strong enough to do aluminum. Can these servos and drives drive it? Will I need timing belts? I have all the plans and stuff drawn out and will definitely post it when I get it done. Thanks and any help will be greatly appreciated John |
| Well, the encoders will work fine with the Geckos but the motors only make ~50oz-in max, that will not be enought for any real machine work maybe just enoght for PCB routing with a small light frame. You can take the ecoders off and buy other bigger motors that don't have encoders (that way they sell for less) and use the encoders you have.
__________________ Dennis |
| ......Although with 5000rpm there is quite a bit of room for gearing, which will increase torque proportionately. Al.
| what you can do is find out the maximum feed rate you require, this will determine the maximum rpm required to achieve this, from this the maximum reduction ratio will be known. Al.
