Old 05-12-2006, 05:17 PM
Bird_E is on a distinguished road
GREX - Are Servos still better then Steppers?
I have a benchtop Mill X3 that I converted to CNC with G320's and servo motors, A couple of years ago, everyone stated that servos were the way to go. Now I have an RF45 clone that I want to convert. With the release of the GREX are servo's still the way to go or should I be looking at steppers now?
Thanks!
BOb
Old 05-13-2006, 11:23 AM
NC Cams is on a distinguished road
Go here for a "give-n-take" treatise on the subject:
http://www.cnczone.com/forums/showthread.php?t=17419
Hint: ALL the high end equipment I"ve ever seen uses servos.
Use the best and you won't be disappointed....
Old 05-19-2006, 11:44 AM
Dan Mauch is on a distinguished road
Servos are the way to go.
While I like steppers quite a bit I have converted all of my machines including a mill/drill similar to the RF45 to servo. Servos are smoother, quiter and don't suffer from lost steps and resonance. I have talked with Mariss and Art about Mach4 and the Grex encoder feed back for steppers. They have indicated it would be quite some time until they were ready. Geckomotion uses it own form of control files not similar to G code. Mach4 will handle the G code but right now it wouldn't handle the encoder feed back as used in a servo system.
Right now the G320 servo amps along with some servo motors I sell (shameless plug) with a 3/1 ratio timing belt would give your machine excellent performance. See www.camtronics-cnc.com
Thanks!
BOb
Dan Mauch
Camtronics Inc
dmauch@seanet.com
www.seanet.com/~dmauch
Old 05-19-2006, 02:08 PM
turmite is on a distinguished road
Hi Dan,
Email sent.
Mike
No greater love can a man have than this, that he give his life for a friend.
