Old 05-03-2006, 09:26 AM
Smackre is on a distinguished road
Gecko Drives
I need to know which gecko drives to use for these stepper motors.
Superior Electric
M091-FD-6217
150 OZ
1.8V 4.7A
Superior Electric
M062-LS-530E
1.65V 4.7A
100 OZ
Also what do i need to power these drives? i read the gecko manual and it says anything from 24v to 80v. Well which would work best for me? Is there any place to buy ready made power supplies?
Old 05-03-2006, 01:43 PM
Gold Member
CJL5585 is on a distinguished road
Superior Electric
M091-FD-6217
150 OZ
1.8V 4.7A
Superior Electric
M062-LS-530E
1.65V 4.7A
100 OZ
According to my old Superior Electric documentation, both of the steppers are 6 wire, with the MO62 having a double-ended shaft.
A Gecko 201 will do the job. The motor curves suggest that for the best performance that a voltage around 36 Volts DC be used.
The best source for a power source would be to check out the power supplies on e-bay and see if you can find one in the voltage range of 28 volts to 36 volts DC with a current rating of around 10 Amps DC. Otherwise, you can visit some of the sites advertised here on CNCZone.
Hope this helps.
Jerry
Old 05-03-2006, 03:40 PM
Well my uncle is a electrician. He told me if i knew what volt and amp i need he could get it for me. I just need to knew the optimin voltage. I hooked the drives ups up to a hobbycnc board. Hooked 2 computer psu's up to it. And tried it but they had no power at all.
Old 05-03-2006, 05:40 PM
ger21's Avatar
Your PM mailbox is full, btw. The best voltage for those would probably be 36V-48V, but it depends how you wire them.
Old 05-03-2006, 06:14 PM
not full anymore
Old 05-03-2006, 06:50 PM
So i need 36v for each Driver. so i need to buy three 36volt power units? what amp do these units need to be.
Old 05-03-2006, 07:15 PM
ger21's Avatar
If they are 6 wire motors, it depends how you wire them, but 1 36V 15amp supply should be fine for all three.
Old 05-03-2006, 08:58 PM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
http://transformertechnology.com/motorpowersupply.htm
Transformer Technology is where I got my PS, its 65VDC 6A
I used the Gecko G201's then I upgraded to the G202's
Eric
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
Old 09-11-2011, 08:12 PM
unns_boy is on a distinguished road
5 phase stepper motor?
Hi, does anyone know if a gecko drives a 5 phase stepper motor? or just 2 phase only?
