Old 05-02-2006, 07:51 PM
Netjams is on a distinguished road
Talking OK the GECKOs work great but
Don't laugh...
I'm running GECKO 201s @50 volts, my screws are 5 turns per inch with 1.8 motors. I was hoping for .001 resalution but it appears I have .0001 resalution.
Using a Qbasic test program I have to send 10,000 steps to travel 1 " hmmm..
It appears that the GECKOs are X10 micro stepping (I have them set @ factory default settings).
I have yet to find a setting to make them step 1 to 1
Old 05-02-2006, 08:44 PM
ger21's Avatar
Yes, they are 10x microstepping. The only way to change them is to add on the step multiplier daughtercard that Gecko sells (which turns it into a G210)
Old 05-02-2006, 11:14 PM
Well after doing the paper test.. puting paper under the Z and testing how thick it is by moving Z up till another piece fit. (this paper is .0004 by the way)
I will be cutting wood and I think I need to upgrade...lol
Old 05-03-2006, 02:04 PM
Gold Member
CJL5585 is on a distinguished road
Originally Posted by Netjams
Don't laugh...
Most of the control software that I am familiar with will do about 40,000 steps per second, so 10,000 steps would take about 1/4 second. Going to a 1 to 1 resolution is only going to reduce the capabilities of your machine.
With a 50 Volt DC supply, and a 5 TPI leadscrew, one should be able to get feedrates of 240 inches per minute with a 40 Khz stepping rate. Not very many materials can be machined at that speed.
Jerry
