Results 1 to 3 of 3
Thread: G320 Locks & Sings, but NO Step
    Gold Member mikkojay's Avatar
    Mar 2006
    Hello,
    I have connected a new g320 to my servo/encoder, and I am having
    difficulty getting it to step when sent motion controls from Mach2
    running on my PC. I have previously used the Mach2 and my LPT1
    breakout board to successfully control stepper motors (using a
    compumotor stepper drive), so I do not believe that aspect of the
    setup is suspect. I have completed the encoder test at the beginning
    of the installation notes document, and from what I can tell, it is
    doing exactly what it should. I hooked a voltmeter up to the test
    points, reset the drive, and watched the voltage go up and down as I
    slightly rotate the motor shaft back and forth. If I exceed 125
    counts from center in either direction, a fault occurs exactly as I
    would expect it to per the documentation.
    Also, I would guess that using the encoder I am using (Heidenhain
    linear), the number of degrees of motor shaft rotation from center to
    fault light was about 2.
    Next, I hook the motor up and reset the drive.
    The motor chirp/hum/sings/vibrates and the shaft is locked.
    If I apply torque to the motor shaft, I can feel the motor fight back.
    I have no experience with servos, but I would think this is all normal
    so far right?
    Next, I open Mach2 and open the Motor Tuning window. I use the
    up/down arrows to generate pulse and direction signals on pins 2 & 3
    of LPT1 for the X axis. The servomotor just sits there and hums.
    I also tried going into the pin output config and trying to change
    from active hi to active lo as an experiment, but it still does nothing.
    I know that the breakout board for LPT1 is supplying a full 5 volts
    for the logic signals- I can watch the pulses on my o-scope. Also,
    again, this output piped into a stepper motor drive works fine.
    Any ideas would be appreciated. I can take pictures of my setup if
    that would help.
    The motor I am using is a MCG 2243-ME2919 rated at 80vdc max.
    The Encoder is a Heidenhain LS143, using its own external p/s. The encoder p/s port is jumpered with a 470 ohm resistor per the instruction manual.
    I am using a compumotor power supply that is currently configured to supply 35 VDC.
    Thanks, Mike
    Expensive tools can be cheaper than professional therapy
    Mar 2006
    It's alive!
    I was so close-
    This thread helped to point me in the right direction:
    Help - Need Gecko Doctor
    It turned out that I was not sending +5v to the common anode side of the optocoupler terminal 12. It has the slide moving back and forth nicely- now I can get back to designing a machine!
    Thanks, Mike
    Mar 2006
    This is worth mentioning- Mariss from Gecko emailed me a reply within one hour (on a Saturday no less).
    His email contained a spot-on solution to the problem.
    Pretty cool.
    Thanks, Mike
