| I have everthing hooked up (I think right) but I can't get the servo motors tuned in very good. When I do get them close they will sing in one direction (most of the time) and hum I the other direction. The motors are 600 oz\in peak Ametek The power supply is giving out 56v @ I am not sure how may amps Gecko 340 drives Us Digital e2 500 ppr encoders More on the power supply The power supply is a toroidal transformer by Antek, I can't find any info about it on the web. It has two primary coils hooked up in parallel (?) and two secondary coils in parallel run hooked up to a birdge rectifier and two capatictors. The only markings on the coil are: model# 7235 Antek i/p 0-115 v i/p 0-115 v o/p 0-35 v o/p 0-35 v The only problem with the poser supply is it will throw a 20 amp 120 volt breaker on a regular basis. What could be the problem? I have worked with it endlessly. |
| you may have a bad breaker, or be drawing too much current occasionally. if you can, lower your max torque settings to limit current. you may need to run a dedicated 30 amp circuit just for your cnc. as an aside, some controllers work better with oversized circuit wiring and power supply because of line drop and peak loads . |
