Old 03-23-2006, 08:01 PM
richyrich212t is on a distinguished road
Can G202's drive these motors ??
Hi all,
Just wondering if a G202 can drive these motors in a series or parallel config.
640 oz/in Model # RHT34-640
Holding torque-Nm (oz/in) +/- 10% 4.6 (640)
Rated voltage 2.3
Rated current per phase (amps DC) 5.5
Resistance (Ohms) +/- 10% 0.42
Induction (mH) +/- 20% typical 3.5
Motor length (mm) 80
Rotor inertia (g-cm^2) 1400
Weight (kg) 2.3
thanks
Old 03-24-2006, 09:00 AM
Gold Member
Mariss Freimanis is on a distinguished road
Yes. Do not use a power supply voltage higher than 48VDC with that motor.
Mariss
Old 03-24-2006, 03:13 PM
thanks for the reply mariss. I was thinking of using the x20 rule and using a supply around 2.3*20=46vdc -=-
Would you suggest something lower maybe ??
Old 03-25-2006, 08:35 PM
Dan Mauch is on a distinguished road
If you need one contact me off line for a 36V DC power supply that will be perfect for those motors.
Dan Mauch
Camtronics Inc
dmauch@seanet.com
www.seanet.com/~dmauch
