I take it the Gecko G320 is limited to only 20A: "0 to 20A current limit adjust range". I'm guessing that means I can never reach my theoretical maximum of 1500 oz-in with the following drives: Reliance Electric DC Brushed Servo Motors, Model E712 37.51 Oz-In/A 25.0-30.5 V/KRpm Motor Terminal Resistance .75-1.02 Ohms @ 4A. Maximum Terminal Voltage 60V Maximum Continuous Speed 2100 RPM (No Load) Maximum Peak Torque 1500 Oz-In. Maximum Peak Current 44.5A Maximum Continuous Stall Torque At Max Motor Temp 300 Oz-In. Maximum Continuous Current 8.9A Is there any way around that? Or, should I just not worry about that at all? Also, does anyone here have any experience with these motors? Will the encoder that comes with them work with the Gecko? Last edited by samualt; 09-19-2003 at 05:41 AM. |
| Rutex offer some drives that run upto 40Amp motors, but they are twice the price of the geckos. You must be planning one big machine to want 1500 oz/in?! edit - just a thought, if you could run them at 20Amp, losing half the torque, you could run them on a reduction pulley, halving their speed, but boosting your torque back up. Obviously you'd need to go for a course ballscrew to regain the speed loss. |
| Samualt, I wouldn't get too distracted by the big numbers of max peak torque and peak current. Those are design limit parameters, not optimum running conditions. The motors will stand 9 amps continuous at 60 volts, so that is what you need, plus a little reserve. If the power supply has a capacitor or two, it may give you the capacity for the peak surges, which are only momentary conditions.
| I am with Hu. 10 amps at 60 volts is close to 2 HP. That's a whack of power. Kong, Using a 2:1 reduction and then using half the pitch is mechanically the same as twice the pitch and no reduction. Eric
__________________ I wish it wouldn't crash. |
| Yup, you can easily break off a 3/4" endmill with 1/2 hp twisting on your screw.
| Hmm...I'm still a little confused. The Gecko's say no more than 20A. So, do I build one power supply for all three motors? If so, what Amps should it output (because its going to 3 motors)? Do I build a single power supply at 60V @ 60A (for all three motors)? Or, should each motor have its own 60V @ 20A power supply? Last edited by samualt; 09-19-2003 at 02:53 PM. |
| samault: three 60v20a pwr sups might be cheaper than 1 60/60 but you will have to shop and see what's available. speaking of high current supplies, what kind of voltage does a small (<100A) cracker-box welder put out? robotic regards, Tom |
![]() Chances are slim that you are going to be pushing all three motors that hard at once, depending on whether you want jack-rabbit acceleration, or not. FYI, I've run Knee mills for years with 12 amp servomotors, and never had a trip out because I was using all three axis at once. Most of the time, the motors have it pretty easy, and are barely warm to touch. The Z axis gets the most workout, if drilling a few hundred deep holes on a peck cycle. My entire controller package runs off a simple 15 amp, 110volt circuit, and I've never tripped a main breaker yet.
#10
![]() Eric
| Gecko's and Deskcnc serial board | Don C | Gecko Drives | 2 | 02-19-2010 11:07 AM |
| A little help hooking up Geckos please | foamcutter | Gecko Drives | 2 | 01-26-2010 06:53 PM |
| My geckos have a mind of their own | bgolash | General Electronics Discussion | 1 | 04-30-2005 01:08 PM |
| Gecko's faulting | dowling177 | Gecko Drives | 2 | 04-08-2005 03:02 PM |
| Turbo CNC and geckos | snoman70 | TurboCNC | 9 | 03-30-2005 07:47 AM |
