11-27-2005, 10:39 PM
| Gold Member | | Join Date: Oct 2004 Location: USA
Placement of the Gecko drives is not critical. The motors can be several feet from the drives. Also, the motor cables do not have to be shielded.
The only semi-critical part of the installation is the step and direction signals to each of the drives. I recommend using a 2 conductor cable for each drive with the step signal on one of the wires, and the direction on the other. If any cable is shielded, it should be these cables. If shielded cable is used,
CONNECT THE SHIELD ONLY AT ONE END TO CHASSIS GROUND. Cut the shield wire off flush with insulation at the other end.
If there is one critical thing, it would be to keep the step and direction cables away from the power supply and motor cables. Keep the two seperated by at least two or three inches, unless they are shielded.
Main thing is to mount the Gecko drives on heatsinks with fan cooling as per the drawings on posts by Benny (Sticky by Ynneb) on this site.
Hope this gets you started.
Jerry
