Results 1 to 4 of 4
Thread: Gecko 203V Drive Fault
    Feb 2005
    I have a machine that runs 3 203V's with a PMDX132 BOB. The problem is that the Y axis occasionally faults(red led's come on) in the middle of a run. Ruined parts because the machine keeps going and the y axis doesn't. I replaced the motor with one off a machine with no problem. I switched the drives around and the problem remains with the Y axis. The wires to the motors are shielded. The setup is mounted on a large heatsink and the drive never gets over 105 degrees F. Anyone have any suggestions?
    Mar 2003
    Shelby Twp, MI....USA
    broken wire maybe?
    Feb 2011
    Be sure your resister is the correct size for the amp draw. If not, it will go red.
    Feb 2011
    check to see if the resister on the 203V is the correct size for the amp draw of the motor. If not, it will go red.
  1. Need Help!- WTF C11G Gecko 203V
    By georgeburns in forum DIY CNC Router Table Machines
    Last Post: 11-01-2012, 10:34 PM
  2. Gecko 203V Alternative
    By richie v6 in forum Gecko Drives
    Last Post: 08-25-2011, 01:23 PM
  3. Will 203V Gecko drive control a Boss 3 stepper motor
    By jbrant in forum Bridgeport and Hardinge Mills
    Last Post: 12-18-2010, 07:55 PM
  4. Problem- fryed 203v gecko drive
    By butchw in forum Gecko Drives
    Last Post: 11-18-2010, 10:30 AM
  5. pac-sci and gecko 203v
    By JKuhn in forum Gecko Drives
    Last Post: 10-07-2007, 12:42 AM
