Results 1 to 7 of 7
Thread: Hi guys
    Registered riche543's Avatar
    Oct 2011
    Hi guys
    Just question about the current resistor for g540
    My steppers are rated at 3.0amps
    So I need 3.0k 1/4 watt 5% resistors is this correct, I'm in Australia & cannot seem too find a source for these here , anyone know of one?.
    Or is there another way around This using other rated resistors to get 3.0k if so how would they have to be wired between pins 1&5 on the db25
    Riche
    Apr 2004
    VA, USA
    The 1/4 watt rating is just a convenient size. If you
    can find 3.0K in a half watt size, that will work fine.
    You can also make up 3.0k ohms by wiring two 1.5K
    in series, or even three 1.0k in series.
    Regards,
    Steve Stallings
    www.PMDX.com
    Oct 2011
    Thanks Steve much appreciated
    Yes I think I found 1/2 watt 3.0k here in Australia
    Thanks again cheers!!
    Riche.
    Oct 2011
    So these are the 3k I can get here , will they work? http://www.jaycar.com.au/productView...k&form=KEYWORD
    Cheers
    Riche
    Oct 2011
    Sorry that link doesn't work for some reason, anyway got some 3k 1/2 watt 1% resistors hope they will do , guy in shop wasn't much help,
    Cheers
    Riche.
    Registered KOC62's Avatar
    Mar 2009
    That is fine Riche.
    By the way you mean the DB9, not the DB25?
    Here is how I did my resistor.
    Oct 2011
    Thanks koc62
    Yep DB9 , & thanks for pic.
    Cheers
    Riche
    1. Newbie- How do you guys do this?
      By slideleft in forum Mastercam
      Last Post: 07-09-2009, 09:14 PM
    2. Hi Guys
      By Jack000 in forum CNCzone Club House
      Last Post: 10-26-2008, 07:21 PM
    3. Newbie- Hello guys
      By Cuttermaster in forum Benchtop Machines
      Last Post: 10-22-2008, 11:15 AM
    4. hi guys
      By pgman68 in forum GibbsCAM
      Last Post: 09-23-2007, 12:57 AM
