So I have been racking my brain and have spent an endless amount of time searching trying to find an answer to my question which is... How do I run my 8 wire steppers bipolar+parallel?
My steppers are purchased from hobbycnc (#23-305-DS8A) which I have 4 of.
Also I am looking at getting a new power supply... So if I have interpreted the information correctly running these steppers @ bipolar+parallel will require 4.2amps each which means 4.2*4*.67 = 11.256. So a 10amp power supply should suffice right? I have also read that if a motors inductance is greater than 5 (which running these steppers bipolar they would be) I should only go with a 36V max power supply.
Any help to clear up my confusion would be greatly appreciated.
Thanks,
Jason
LinkBack URL
About LinkBacks
