Results 1 to 6 of 6
Thread: Motor tuning Gecko G540
    Jan 2005
    I made a little video on how I adjusted my motors on my mill with the Gecko G540. I'm sure there are other ways to do this but this way worked for me.
    This is a not the newest G540 that has the pots close to the cover. I would guess that they would adjust the same way only easier to find the screws.
    I hope someone finds this useful.
    Dec 2007
    I'm sure a lot of people will find your video useful! Thanks for putting it up, your mill also seems very capable from the aluminium milling!
    cheers,
    Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
    Jan 2005
    It seems that some people must be finding it useful. I got a number of views on youtube.
    Like I said in the video. The most important thing when tuning the motors with the G540 is to use a plastic screwdriver. About 2 years ago I made the mistake of trying to adjust it with a metal one and shorted something out on one of my drives. Lucky that I only needed 3 drives to run that machine so I used the extra one in place of the bad one and didn't have to replace the shorted out one.
    Feb 2012
    Where did you get a plastic screwdriver?
    Jan 2005
    Quote Originally Posted by FloridaNole View Post
    I made the screwdriver from some delrin round stock.
    Dec 2007
    Don't know about in the States, but here we get them in packs of 4 or 5 for around $3 from any of the cheap Asian mixed goods shops. You should be able to get them from any half decent electronics supplier or TV/Audio repair centre if you have any trouble. They are pretty standard fare, with the good ones being usually ceramic, as to not induce any interference in adjusting RF gear.
    cheers,
    Ian
    1. Sweet Spot - Tuning G540
      By Bob La Londe in forum Gecko Drives
      Last Post: 01-19-2012, 06:13 PM
    2. need help for g540 motor tuning.
      By Technogod in forum DIY CNC Router Table Machines
      Last Post: 11-06-2009, 11:47 PM
    3. Need Help!- Need help with motor tuning mach 3 REX RHT34-640 Gecko 201 drive with camtronics box
      By MAKESOMECHIPS in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 04-07-2009, 01:19 PM
    4. Replies: 3
      Last Post: 03-18-2009, 10:38 AM
    5. New Machine Build- Gecko G540 and Motor mH rating
      By ronateah in forum Gecko Drives
      Last Post: 11-18-2008, 11:05 AM
