Results 1 to 5 of 5
Thread: Auto zero g540
    Jan 2012
    Question Auto zero g540
    After reading on the subject I do not understand why some uses resistance ...
    Does anyone can help me with the connection of the autozero tool please ... and do i need resistor or not .. and why use it ?
    Dan
    Jan 2012
    nobody can help me ?
    Registered doorknob's Avatar
    Jan 2010
    Can you post one or more links to what you have been reading?
    I can not be certain from your description, but it is possible that the resistor that you are talking about is a "pull-up" resistor which would hold an input pin to a logic "high" value until a probe grounds out that input - in that case, your software would be looking for an "active low" signal to signify the zeroing of the touch plate.
    Jan 2012
    Hi doorknob
    yes I was talking about the "pull-up" resistor
    How can I know more about the "pull-up" resistor for my g540 gecko drive, I don't know exactly what kind I need to do this ...
    Thank you
    Dan
    Jan 2010
    I guess that I'm a little bit reluctant to give advice on this at the moment (without looking at the articles or posts that you have read) because I haven't actually done a touch plate with my G540.
    My understanding is that each of the four inputs to the G540 may already have an internal pull-up resistor, because the inputs already are designed to look for the pins to be grounded to send a signal that can be read by Mach3. So, if that is correct, then I don't think you would need or want to add an external pull-up resistor.
    1. auto oiler help
      By MarshCustom in forum General Metalwork Discussion
      Last Post: 04-03-2013, 04:18 AM
    2. Verified Auto Tool Zero for Ver .032, SmoothStepper, G540
      By m1911bldr in forum Mach Software (ArtSoft software)
      Last Post: 12-05-2009, 02:07 AM
    3. auto set z
      By Ed Williams in forum Mach Mill
      Last Post: 04-10-2009, 09:13 AM
    4. Help Bobcad Auto-cut
      By beausdn in forum BobCad-Cam
      Last Post: 09-03-2007, 12:46 AM
    5. Auto Tool Zero
      By Moondog in forum Machines running Mach Software
      Last Post: 12-22-2006, 07:02 PM
