Results 1 to 8 of 8
Thread: G540 Promitity switches on one input?
    Dec 2007
    Is it possible to put 3 proximity switches on one input?
    Dec 2003
    Usually possible In parallel if they are open collector, and depending somewhat on the nature of the input?
    I believe the G540 is sourcing input so you would need O.C. NPN outputs on the Prox.
    Dec 2007
    What is O.C? Do you mean normally open? I was thinking about using this ones New LJ12A3-4-Z/BX Inductive Proximity Sensor Switch NPN DC6-36V | eBay
    Registered doorknob's Avatar
    Jan 2010
    There are different styles of NPN output proximity sensors, and it is not clear to me which style is used by the eBay one (but the price is very tempting).
    An OC or "open collector" NPN output would be like the one described here (open collector means that there is nothing connected to the collector of the output transistor other than the output terminal):
    PMDX.COM - Products for CNC and motion control applications
    From that page:
    The normally open NPN output allows multiple sensors to be paralleled into one PMDX input. The output is "open collector" and pulls the signal to ground when active.
    By connecting multiple sensor outputs in parallel you would be doing a "wired OR" connection (where the signal could come from any of the connected sensors).
    Contrast that with the "loaded" NPN output transistor shown here (on page 2 and page 3):
    http://www.redlion.net/Products/Grou...Docs/PSA-A.pdf
    In that one, there is a built-in "pull-up" resistor to the 12 volt line connected to the NPN output transistor's collector, which would probably not be suitable for the application that you have in mind. However in that app note they claim that it can be used in place of an open collector type, with certain provisos:
    Note: PSA-6A, 7A, and 8A outputs are NPN loaded collector outputs
    which contain an internal load resistor that is returned to +VDC for
    internal feedback purposes. This does not interfere with the ability to
    use these sensors as conventional “Open Collector” outputs, as long as
    the +VDC for the proximity sensor is supplied by the indicator or
    control receiving its output signal. A PSA-6A, 7A, or 8A may be used
    as an input to more than 1 indicator or control only if the respective
    power supplies are “unregulated” and can load share. These supplies
    may then be paralleled together as shown. An indicator or control with
    a regulated power supply may not be paralleled.
    Dec 2003
    Quote Originally Posted by LazyMan View Post
    You could always send a question for more info on it.
    As well as O.C. (open collector) you need to know if it is either N.O./N.C.
    Normally open/closed.
    For parallel operation you need N.O.
    Registered anthropod's Avatar
    Jul 2010
    I think I have my head wrapped around this G540 and proximity switches now.
    I have:
    (1) G540
    (1) 48Volt Power Supply
    (5) Inductive, Normally Open, NPN Three wire Proximity Switches. 10 to 30 Volt DC
    On order I have (1) DC-to-DC regulator to bring down the voltage of my PS to below 30.
    If I wire them in Parallel I should be able to only take up one input. (Although I may use three inputs, one for each axis.)
    Does that sound correct?
    Jan 2010
    It sounds correct to me.
    Jun 2011
    Yes it will work if your sensors are capable of working in parallel!
    I using NPN Open Collectors 3wire prox sensors...
    I have three connected in parallel for my home switches.
    I use a separate 24 vdc sensor/relay pwr supply for them......
    Stuart
    1. mach 3 input switches labeling
      By ramkitty in forum Mach Mill
      Last Post: 08-29-2011, 01:15 PM
    2. G540 input 1 not working !
      By Action-KAT in forum Gecko Drives
      Last Post: 05-12-2011, 02:08 PM
    3. G540 Spindle input?
      By blades in forum Mini Lathe
      Last Post: 04-25-2011, 07:48 AM
    4. Spindle input to G540?
      By blades in forum Gecko Drives
      Last Post: 04-23-2011, 11:48 AM
    5. G540 signal input
      By MArruda in forum Gecko Drives
      Last Post: 12-23-2010, 09:22 AM
