Old 02-02-2012, 12:13 PM
kosmo is on a distinguished road
203V and bridgeport stepper wiring
Looking for BP stepper motor parallel wiring schematic with motor phase connections to Gecko 203V drives. Having trouble finding a straight forward diagram. Thank you !
Old 02-02-2012, 01:32 PM
keebler303 is on a distinguished road
The steppers have six wires, correct? There will be two phases, you need an ohm meter to find which wires are for which phase. There is a center tap plus each end wire on a coil (3 wires per coil) The two ends will have a higher resistance between them while the center tap should be roughly half the resistance. Find the two end wires, for each phase. Those are the 4 you will connect to the G203V. The center taps are not used with bipolar drives and should be insulated from all other wires.
Matt
Old 02-02-2012, 01:37 PM
Measure the resistances to find the correct wires. See attached.
Matt
Old 02-02-2012, 08:35 PM
Gold Member
Mariss Freimanis is on a distinguished road
If the motor has a name-plate rating of 7A or less you will get better performance (double) if you use the center-tap and one end wire compared to the end-wire to end-wire connection suggested here.
Mariss
Old 02-13-2012, 05:55 PM
Found a diagram for bridgeport stepper wiring in parallel. I have not tested this but will update findings when retrofit is complete
Name:	motor wiring.png‎
Will 203V Gecko drive control a Boss 3 stepper motor jbrant Bridgeport and Hardinge Mills 9 12-18-2010 06:55 PM
Need Help!- 203v and the Yellow LED (No Stepper Connected) Regnar Gecko Drives 0 04-16-2010 07:41 PM
Need Help!- Wiring a C11g Board and Gecko 203v for lathe adbradley Stepper Motors and Drives 7 11-09-2009 11:49 AM
Need Help!- gecko 203v won't turn my stepper benjamint76 Gecko Drives 1 07-27-2008 01:47 PM
Hooking up my stepper to the 203v gets the red and green... bitviper Gecko Drives 8 06-16-2008 09:07 PM
