hi guys, not sure if the red light on the G540 for all axis should be green or it's normal that it's red? few months ago I bought the V90 with USB controller - after having issues with loosing steps, communicating this with planet-cnc (which provide software), I decided to go easier way - bought Geckodrive G540 and trying set-up everything with Mach3 have power green light using HT23-280-8 with 2.1k resistor, wired in series check protobix web site for more detail - not able put url ;-( could turn the motor through Mach3, didn't try calibrate or do more as I'm not sure if the red light is ok or not somebody who can help?? |
| See Step2 and Step3 in the manual. http://www.geckodrive.com/images/fck...4%20MANUAL.pdf
| thx, however I described my issue not understandable, sorry for that so I do have the power LED green the four led(s) for axis are RED question is if this is ok or if these four lights should be green after plug the DB9 connector once I plugged the DB9 connector the power LED stay Green and I could turn on/of the motor through Mach3, I just don't know if the RED light for all axis supposed to be green or if it supposed to stay RED thanks again |
"The red LED will be illuminated if there is no jumper connecting these two terminals" you really should read it John |
| one more time - the POWER LED is GREEN - I don't have issue with jumper or E-stop my question is on the 4 red lights - visible through hole for adjusting the trim there is nothing in the G540 manual about these 4 lights, or I'm not able find it |
| You are referring to the 4 red LEDs you see looking into the 4 "adjust" holes. It is normal for them to be on. Those LEDs are being used as 1.8V voltage regulators on each of the 4 motor drives inside the G540. The red LED that matters is the one next to the green LED on the front panel. It indicates a FAULT condition. Mariss |
| G540 fault light...what does that mean? | HereinCS | DIY-CNC Router Table Machines | 3 | 03-06-2011 07:37 PM |
| G540 power light ? | llamatrails | Gecko Drives | 2 | 09-13-2010 06:53 PM |
| Need Help!- G540 Green Light..Go or no go? | ronncat | Gecko Drives | 15 | 01-02-2010 01:11 PM |
| Need Help!- G540 Fault light | cnccustom | Gecko Drives | 14 | 01-06-2009 12:53 AM |
