Hi, Is there anyway to feedback from the gecko 203v to let Mach3 know the dirve faulted? Since the yellow LED comes on I think this might be possible. Last night I lost a very nice piece of wood because the Z-Axis faulted. Thanks, Bob Stack
__________________ GO-Tech: Geek Show&Tell Meets Ann Arbor 2nd Tues at www.maker-works.com South East MI cnc meets 1st Wed at www.maker-works.com |
| What caused the fault? A stepper drive shouldn't fault while running.
| There doesn't appear to be a drive fault output available? Al.
| I'm not sure what faulted the motor. This is the 2nd time this has happened. gecko is on a heat sink and there is a fan blowing across it. I"m using: 570 oz stepper with a 2:1 ratio 5tpi ballscrew NXK linear bearings The My Z axis with spindle is probably around 25 lbs. I'm using a chinese import spindle around 12lbs + fluid bearings + plates... I ordered a gas spring last night to help offset the weight but I"m not sure that is the problem. Any suggestions would be appreciated. Thanks, p.s. I am working on another cnc and I'm going to go with servo's next time.
| I would think that is a bit of oversight in design, many drives have a fault output, especially in the case of a stepper where there is no closed loop to detect an error in motion? Al.
| Turns out the fault was caused by a short. I crushed a wire when I moved it from our shop, the coolest shop on earth (Home) to my home. Having a fault/error output would be a good feature. Perhaps in the future. I have started a new build and this time I'm going with servos... Thanks for the replies, Bob
| Problem- Mach3, 203V and steppers losing steps - looking for items to check | bseibenick | Mach Software (ArtSoft software) | 36 | 04-24-2012 03:54 PM |
| Difference between 201, 202, and 203V?? | flash319 | Gecko Drives | 1 | 04-20-2009 07:44 PM |
| Calculating "steps per" in Mach3 with Gecko 203V | millman52 | Machines running Mach Software | 7 | 11-28-2007 03:04 PM |
| pac-sci and gecko 203v | JKuhn | Gecko Drives | 0 | 10-06-2007 11:42 PM |
| 203v and candcnc bob? | ged | General Electronics Discussion | 1 | 02-18-2007 12:08 AM |
