I`m having a hard time getting my new Taig mill with Gecko 540 from DeepGroove1 working reliably. I`ve been having a lot of problems with random faults. I thought I`d cured them yesterday by disabling the 2nd CPU and Hyperthreading, and have been able to make 3 quite complicated pieces (5 hours, 30 minutes, and an hour run time respectively), but now its faulting again about 20 minutes into a job. I`m using EMC, on a Xeon 2.8Ghz CPU (same as a Pentium IV but supports dual CPUs). Any ideas? What does the fault light actually indicate? |
| Do you maybe have really thin serial cables going to your motors? I found that the 25ft and 20ft cables I had originally planned to use would cause random faults while moving. Motors were not attached to the table. As soon as I made up some proper cables with 18awg wire, my problem went away. |
| I was taking the gecko unit out of the controller box to return to DeepGroove1, and the ground wire fell out without me unscrewing it. I re-mounted the gecko upside down so I could get to the terminals easily, secured all the wires, and it has run for about 7 hours without faulting so far.. |
| A loose wire inside the cable was one of my problems, I also found a loose wire inside the controller box, where the wires screw into the gecko. If you pull on them they shouldn't fall out. I then proceeded to have lots more problems that were eventually solved by pointing a fan at the back of the Gecko. Hope this helps! |
| G540 random fault | cd_edwards | Gecko Drives | 0 | 01-02-2012 03:34 PM |
| Need Help!- Random g540 Faults | bjmrtn | Gecko Drives | 4 | 12-18-2011 08:16 AM |
| g540 Faults with more than 2 motors hooked up? | R08ert209cali | Gecko Drives | 1 | 11-28-2011 01:26 PM |
| G540 Random fault light on power up | mchm66 | Gecko Drives | 6 | 09-05-2011 03:51 AM |
| random stalling g540 | ihavenofish | Gecko Drives | 8 | 05-04-2009 12:49 PM |
