Old 01-09-2012, 03:07 PM
keebler303 is on a distinguished road
G320 Position Error Fault Disable
I am using a G320 for a special application. I'd like to have unlimited position error. I think I can accomplish this by cutting the trace from the window comparator to the fault latch. I fully understand I might fry it, blah blah blah. If anyone "in the know" could tell me which trace it is I'd appreciate it. Would save me some time finding it. I know its near the test point but things get crowded fast.
Matt
Old 01-09-2012, 04:11 PM
I think I found what I wanted, but after thinking about it I don't think it will be of use as the U/D counters are going to roll over anyway... on to plan B...
Matt
Old 01-09-2012, 04:15 PM
Larken is on a distinguished road
I don't think Marris would recommend what your doing
What probably will happen if the fault gets ignored is the counter will overflow back to zero and the motor will Jump back violently.
Best way for unlimited position error is to not mount the encoder on the motor
Manufacturer of CNC routers and Viper Servo Drives
www.LarkenCNC.com and www.Viperservo.com
Old 01-09-2012, 08:37 PM
the blah blah blah in my first post covers your first comment, but beyond that I don't have an encoder on the motor. Mine actually runs on a web which is rolled up by the motor through lots of gear reduction. I still need closed loop because the speed needs to change as the roll gets bigger to maintain constant speed. I don't actually want unlimited error, but I sometimes get oscillations due to the system being underdamped for how it is arranged. The oscillations will cause nuisance faulting which pauses mt process every 5 seconds.
I have another setup that works great using a baldor vector drive and auxiliary encoder but thats around $5k. I'll continue to make due with my setup until something better comes along.
Matt
VMC15 fadal, 88HS error#9, spindle driver fault, servo amplifier fault kin73 Spanish CNCzone 3 05-17-2011 11:26 PM
G320 Power-up Fault Mariss Freimanis Gecko Drives 2 11-22-2009 11:33 PM
G320 Fault & Mach3 THend Mach Software (ArtSoft software) 2 11-11-2008 11:07 PM
Tie G320 fault line to something ? embeddedJunkie Gecko Drives 2 05-31-2007 11:37 AM
G320 Fault light doesn't turn off lamote Gecko Drives 0 04-11-2005 04:39 AM
