I would like to run my new Gecko 203V as close to the 80V ceiling as possible, but I don't want to trip it with line fluctuations. How close should I run it? I was thinking 76 or 77 Volts. If it helps, I will also be running the 7A limit. |
| The G203V does not "trip" at 80 volts, it is just rated at 80 volts. This rating is based on the voltage tolerance of the components inside and reasonable engineering decisions about their expected lifetime. Running higher voltages than specified, especially at maximum current will reduce life expectancy. Voltages higher than 80 volts will shorten lifetime as the voltage gets higher that the design value. The limiting value is somewhere above 100 volts where the lifetime becomes milliseconds. If you want to push the G203V as far as possible, consider the following: 1) Use a power supply that will not produce greater than 80 volts output, even if the mains voltage goes above what is expected. You can achieve this with an unregulated power supply by setting a target voltage that allows for enough margin to allow for the mains voltage to exceed the expected voltage by 10 percent or more. We typically recommend 70 VDC as the nominal supply output voltage. 2) Use a power supply whose output voltage is regulated. This can be expensive, but will allow you to run at 80 volts without worrying about mains voltage fluctuations. 3) If you will have situations where the motors will have to decelerate a large moving mass, then provide a clamp or dump circuit that can absorb the energy returned by the motors so that they do not drive the DC supply voltage up by pumping energy back in to the supply. 4) Provide the G203V drivers with good heatsinking to keep component temperatures down. The mounting surface of the heatsink plate must be flat and a thermal coupling medium such as white thermal grease or a compliant thermal gasket should be used between the G203V and the heatsink. Fans can help cool the heatsink, but make provisions for making sure the fans are working and that dust or other debris does not block the air flow. The principal advantage of a higher supply voltage is faster motor speed. A supply that delivers 80 volts will result in the motors being around 11% faster than with a supply rated for 70 volts. Is this really worth all the cost and risk? Regards, Steve Stallings www.PMDX.com |
| Steve, I greatly appreciate the response. Thanks for clearing up the 80V trip confusion. Plenty more to think about now. 11% really isn't much. I think I'll go with your recommendation of 70V. I also already have a dump circuit that just needs put together. To top it off, I have mega (~8"x8"x6" or something) heatsinks I got for a very good price that I plan on using. I think all this should fit the bill. Again, thanks! |
| Oops, my bad, the speed difference between 80 volts and 70 volts would be around 14%. It is directly proportional to voltage, i.e. 80 divided by 70 gives 1.14 or 14% more speed. Regards, Steve Stallings www.PMDX.com |
| Hi Steve, Just to clarify that for motor, if we use higher voltage for example kelling DC servo motor rated 90 VDC, if we run at higher voltage about 100 vdc, it will not hurt the motor. But it will damage control. Is it recommended to run at higher voltage above motor rated voltage for example I use granite device 160 VDC, so I can run motor w/100 vdc that is above motor rated voltage (90 vdc). |
| I believe that if you run servos over their rated voltage, they will be destroyed.
| The voltage rating of a servo motor is voltage across its input terminals. The voltage output by a servo motor driver will typically be slightly less that the power supply voltage, so it is common to see 90 volt servo motors using servo amps connected to a 100 volt power supply in order to get the most out of them. Gecko servo motor drivers would not likely live very long if you tried to run them at 100 volts, they are rated for an 80 volt power source. The ratings on servo motors are mainly about the following issues: 1) voltage - Sets the rated voltage to achieve the rated speed. Servo motors will have a speed limit beyond which they fail mechanically, but this is often greater than their rated speed. This is because the rated speed is stated as a lower value in order to correlate to other desirable properties that are specified at that speed. You may be able to run the motor faster but with lower torque for example. Don't take this as an excuse to run a 3000 RPM motor at 10,000 RPM - that would likely kill the motor, but running a 1500 RPM motor at 2000 RPM might work as long as you accepted lower torque as a side effect. 2) continuous torque - This is the rating that relates to heat generated inside the motor. It is also directly related to current. Usually the motor driver is set up to allow short bursts of peak torque, but limit the average continuous torque to avoid overheating the motor. 3) peak torque - This is where servos have their advantage over steppers. Most will allow short bursts of torque 3 to 5 times their continuous rating. This allows more power when needed for quick acceleration. "Short" in this case is in terms of the thermal time constant of the parts of the motor that can be damaged by heat and usually refers to only a few seconds in duration. As before, peak torque is directly related to peak current. Current in excess of the peak rating can cause mechanical damage, erode brushes, and for some older designs, can cause the permanent magnets to be partially demagnetized and weaker. Servo motors, like most electromechanical devices, can be pushed beyond their ratings, but you must accept the fact that their useful life will be shortened by doing so. Regards, Steve Stallings www.PMDX.com |
| Tags |
| gecko 203v, max volts |
| Need Help!- running emc as a simulator, running out of ideas | CaptainVee | LinuxCNC (formerly EMC2) | 48 | 02-16-2012 12:30 AM |
| Why would anyone pay this for geckos? | Madclicker | DIY-CNC Router Table Machines | 9 | 03-18-2006 09:40 PM |
| Where are my Geckos? | JMValios | Gecko Drives | 5 | 12-03-2005 05:33 AM |
| Are My Geckos Bad | moto21 | Gecko Drives | 0 | 09-21-2005 05:49 PM |
| Geckos 101 | anoel | Gecko Drives | 14 | 08-23-2003 02:18 AM |
