Old 01-02-2012, 03:34 PM
cd_edwards's Avatar
cd_edwards is on a distinguished road
G540 random fault
Today, I was working on my 8020 CRS build and discovered something weird. When I was bench testing the motors and my cabinet, I never had a problem with the G540 at all. Once I moved everything over to the router I was getting random faults while running roadrunner.tap. I tried a few things including turning off the watchdog, disconnecting motors etc. Finally I decided I had better try using the "original" cables I had used when setting up the
G540 instead of the "new" cables I had on the table. Imagine my surprise when it started working perfectly. The only thing I can see differant is that the cables I had originally used were thicker than the new cables I was trying to use.
So, if you are finding random faults with the G540, try a differant cable with larger wires in it. It just might cure your problem.
PS, anyone wanna buy some hardly used 25ft serial cables? cheap! I have 5 of them
Need Help!- Random g540 Faults bjmrtn Gecko Drives 4 12-18-2011 08:16 AM
HELP, mach throws up random ESTOP mid program. Gecko G540 dougie329 Mach Software (ArtSoft software) 3 12-04-2011 12:35 PM
G540 Random fault light on power up mchm66 Gecko Drives 6 09-05-2011 03:51 AM
New Machine Build- G540 fault Dean448 Gecko Drives 2 08-04-2009 10:42 AM
random stalling g540 ihavenofish Gecko Drives 8 05-04-2009 12:49 PM
